Old 10-07-2020, 11:34 PM #1
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
Bad idle air control valve ??
My engine is making a new noise that started suddenly.
I am having a problem with idle speed. I must SLIGHTLY rev the engine until it warms up. if I do not do that, the engine will shudder and stall.
Once warmed up engine will run but not smoothly.
Now, about that mysterious noise. It is NOT a loud BANGING. But still quite loud. More of a loud tapping than a banging. Hard to describe the noise but by using a mechanics stethoscope the noise APPEARS loudest at the base of the throttle body. throttle body.
I suspect that it could be a dirty, sticking IAC. I intend on removing the throttle body and cleaning both it and the IAC.
I'm but sure but I think the electromagnet spins and may be causing the noise
Has anyone experienced an IAC valve that makes a loud noise ?
Traveler74 is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 12:04 PM #2
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
The IAC valve has a spinning part in it. So if you hear noise from there that's probably the issue
Old 10-08-2020, 10:19 PM #3
Thank you, jross. If my cleaning of the IAC valve, does not work, I'll replace it with a new one. I sure hope that is the problem and NOT a rod knock.
Old 10-09-2020, 04:31 AM #4
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Originally Posted by Traveler74 View Post
... I sure hope that is the problem and NOT a rod knock.
Rod knock is loud as can be, can be heard down the street, like a 5lb hammer banging and there will be metal in the oil/filter....
body , engine , loud , noise , throttle
Idle Air Control valve question TXRick 3rd gen T4Rs 17 03-21-2016 11:17 AM
IDLE AIR CONTROL VALVE 85 4runner 58rennur4 Classic T4Rs 7 04-19-2015 08:04 PM
idle air control valve hairysrunner 3rd gen T4Rs 15 03-16-2015 03:12 PM
Idle Air Control Valve ford2774 Classic T4Rs 0 06-28-2007 08:13 AM
Idle Speed control valve 3rdGENrunner Maintenance/Detailing 7 01-10-2006 02:13 PM
