Old 10-10-2020, 09:46 AM #1
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
12Volt Guy elocker harness wiring/illumination Q
Sorry for the long winded post in advance-
Is anyone on here using the 12Volt Guy stand-alone elocker harness these days? It used to be pretty popular but haven’t seen many posts about it lately.
I have the harness and did the install last night in the wee hours. Obviously a very easy install, given it’s standalone and basically plug and play.
My truck is an SR5 and still has the stock unlocked axle in the back. I have an elocker axle ready to go in. I just wanted to go ahead and “pre-wire” as much as possible so the axle swap is plug and play. I’m leaving the 2 plugs in the interior and will drop them through the fuel tank opening in the floor when the time comes to get the elocker axle in.
However, I had a couple of questions for guys who run this harness:
- Where did you guys end up grounding the two ground wires- the black and brown ones. Under the dash somewhere? I’m currently grounding these two wires through one screw near the kick panel, but wondered if there’s a more optimal place. Seems like a lot of paint etc in there.
- What wire did you tap into to operate the switch LED lights? I tapped into the green w/silver stripe coming off of the ignition switch.
That said..
Not getting any illumination, even with lights on. I’m wondering if the switch will not get any illumination at all if it’s not actually plugged into an elocker position switch and elocker motor.
Basically the situation is that everything up front is hooked up- from battery, through an in-line fuse, to switch, grounded- the whole 9 yards..
Then the harness runs back and doesn’t plug into anything (yet)
Is this why my switch isn’t illuminating with the headlights on?
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 10-10-2020, 10:12 AM #2
SeaBassHWD SeaBassHWD is offline
SeaBassHWD will become famous soon enough
You need it plugged into the locker for the switch light to turn on. If you already have the pumpkin locker, just plug it in so you can see it working. I did this when I installed my elocker using the 12vguy harness to make sure everything worked beforehand.
SeaBassHWD is offline   Reply With QuoteReply With Quote
Old 10-10-2020, 10:33 AM #3
Thanks! I figured this must be the case. I’ll give this a whirl tonight.
I wonder if I should have some basic illumination of the switch though- not related to the elocker function, but just basic nighttime illumination. It may need to be all plugged in for that too
Old 10-10-2020, 10:36 AM #4
Mine only illuminates if locker is in locked position.
Old 10-11-2020, 10:20 AM #5
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
I think it needs to be plugged in even for the illumination. Mine is on all the time when it is running and even brighter when it is locked. A little too bright for my taste but fine in the daytime
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
axle , elocker , harness , i’m , switch
FS: Low Range Offroad Ultimate Toyota ELocker Wiring Harness Kit -DENVER rkymtnman For Sale: T4R Items 9 12-09-2017 12:41 PM
12volt guy or lowrangeoffroad for elocker harness? bama16 3rd gen T4Rs 3 06-11-2016 12:24 PM
Elocker retrofit wiring harness cj80cruiser 3rd gen T4Rs 4 06-22-2013 04:16 AM
Metra Wiring Harness - Illumination wire KAX Engines / Suspension / Wheels / Tires / Audio / Accessories 8 07-17-2012 03:17 PM
