Perhaps you're not remembering it correctly, the quick RRDIFF LOCK flash either means your moving to fast to engage RRDIFF LOCK, or the vehicle thinks you are, or you're not in 4Lo or grey wired. Either way it should be a slow flash and it should atleast click at the locker to make an attempt if all is well back there and at switch and everything mentioned earlier is satisfied, sounds like something isn't happy with the switch, did you losen up your grey wire ground by mistake or damage the connection. It's only 2 wires on the RRDIFF Lock button unless you added the illumination like the Tacos got, I stuffed an LED in mine.
