Old 10-11-2020, 05:58 PM #1
Wraytex Wraytex is offline
Wraytex is on a distinguished road
Rear brake backing plates rusted.
What’s the best way to go here? The replacement parts are pricier than I anticipated.
Wraytex is offline   Reply With QuoteReply With Quote
Old 10-11-2020, 06:10 PM #2
DMiller DMiller is offline
DMiller is on a distinguished road
i am also interested as the drivers one on my 2000 has some rust issues. Passenger one seems intact.
DMiller is offline   Reply With QuoteReply With Quote
Old 10-11-2020, 06:53 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well you have 3 options:
1] find south rust free axles replace bearings etc and use them
2] take your axles out have everything pressed off replace what's bad and replace the plates
3] convert to rear disk kit that a member made in the forum
Tim has step by videos on the procedure of changing axles and ot back plates. ;)
Old 10-11-2020, 07:21 PM #4
Thanks, i’ll look those videos up. I wasn’t looking for a project but one seems to have found me. A full rebuild is in the works either way I go.
Old 10-11-2020, 08:23 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Those plates are fairly thin. They rot through on a pile of rigs. It's one if the reasons they built that disc conversion kit for the 3rd gens. To convert you cut that plate basically all off..
Old 10-11-2020, 10:49 PM #6
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
When I replaced the rear axle seals & bearings on my 02 with 180K miles I decided to replace both brake backing plates as they were badly rusted through.
Ordered them online from Conicelli Toyota @ $95 a piece.
It’s a good time to also dismantle and clean up the bellcranks.
Not cheap but oh so nice to have something on my rig that is solid and rust free.....for now.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 01:05 AM #7
toverturf toverturf is offline
toverturf will become famous soon enough toverturf will become famous soon enough
One of mine has a small hole in it. I plan on doing the disc brake conversion in the springtime.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
toverturf is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 09:35 PM #8
BrianK14 BrianK14 is offline
BrianK14 is on a distinguished road
If the backing plates are rusted significantly, chances are the axle housing is as well. If your going all out, you may consider finding a rust free rear end housing from a salvage yard, EBay, etc, including axles/backing plates. Might not be much more than just new backing plates from Toyota
BrianK14 is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 11:15 PM #9
calebb calebb is offline
calebb is on a distinguished road
I've seen 2 extremely clean and rust free 4runners this past year in the rust belt at my local junkyard. Took the axles off, told the guy I only wanted the backing plates and ended paying $20 for rust free backing plates. That's one way to do it.
calebb is offline   Reply With QuoteReply With Quote
Old 10-13-2020, 05:06 PM #10
Brian, if I were to build up another Axle, would any 3rd gen housing work with the E locker?
Old 10-13-2020, 05:41 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Non and e locker axle housings are different. As well as 2 different ratios or factory e lockers I believe. Brian or another user can verify this and correct if necessary.
Old 10-13-2020, 09:04 PM #12
Yes, you need an elocker housing, unless you want to spend a lot of time modifying a standard housing to work. When my original housing started leaking, I bought a rust free elocker housing, drum to drum, but no third member, on this site for $225. Did a elocker conversion and got rid of a lot of rust.
Old 10-13-2020, 09:30 PM #13
Thanks for the help. I’ll look for a bit. It’s a hunting rig at our place so it’s nothing that’s needed yesterday.
Old 10-14-2020, 10:41 AM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You can actually get replacement back axle housing to replace the rusted pan the 3rd member fill plug is on. However, mostly if they are that rusty. Its best to replace the entire housing. I just wanted to mention it as users my have a pin hole only in the pan and can replace it if need be. :-)
Old 10-15-2020, 01:53 PM #15
I got lucky and located another rear locker axle (and extras) for 1000$ This one's rust free.
Rear brake backing plates rusted.-img_4132-jpg
brake , parts , pricier , rear , replacement
Front spindle backing plates / splash guards Dezerts10 3rd gen T4Rs 6 07-24-2020 10:46 PM
Deleting brake backing plates? eimkeith 3rd gen T4Rs 1 06-29-2017 09:54 AM
Replacing rear brakes w/rusted e-brake Jack08520 3rd gen T4Rs 2 10-20-2016 10:39 AM
Rear Brake Backing Plate Sheild Rebuild cferry7 Classic T4Rs 5 11-26-2015 05:49 PM
