11-02-2013, 12:42 PM
Originally Posted by mamukaok
I go and get Shell Rotella T oil at wally world for all of my vehicles. I use the 10W-30 Synthetic in my runner. I've read a lot of good things about it, and best of all, it's cheap.
Honestly, it doesn't matter what brand oil you put in it. The no name stuff will work just fine. Just grab the weight that is good for the temperatures you will see. There's all kinds of info on synthetic vs conventional online.
11-02-2013, 12:43 PM
Changing your oil is far more important than what type of oil. Get a oil with seal conditioners like you have found and you should be fine.
I use Mobile 1 high mileage or Valvoline max life.
11-02-2013, 12:51 PM
Japanese car's don't care too much.... but the SAE ratings are crap.
'94 SR5 V6, 2" body lift, 4.56 gears, 31x10.50-15, Hella 500's (needs less stock!)
Originally Posted by KidVermicious
I wouldn't be opposed. With another kid on the way, four doors is looking more and more attractive.
11-02-2013, 12:54 PM
The Maxlife will serve you well.
Mobil Super High Mileage is also a good choice.
11-02-2013, 02:12 PM
That Motor Oil is fine to use.
I would guess you are likely our only member from the Republic of Georgia. Welcome.
11-02-2013, 02:16 PM
Pennzoil, Castrol, Valvoline, Redline, Motul, etc. will all work fine. Just stick with name brand oil and buy the correct grade. I would get 5W30.
11-02-2013, 02:37 PM
I would also say you might want to do something like Pennzoil or Valvoline high-mileage conventional 5W-30.
Some people might say here to go fully synthetic with Mobil1 or Amsoil, but if your engine has ran since 1998 without it, I'm not sure it's the best choice to 'convert' now.
Like someone said earlier in this thread though; changing oil on a consistent basis is more important then the synthetic vs conventional argument.
11-02-2013, 03:43 PM
Mobil 1 10/40 and a quart of synthetic Lucas. It should be obvious to use a good disposable filter.
'16 Super White Trail Premium w/KDSS, Icon stage 2 w/track bar, TRD Pro modified skid plate, TRD Pro wheels, BFG MT 255/80's, 5% tint.
Instagram: Rockyf36
11-02-2013, 04:15 PM
I use Mobil high mileage 10w-30, mainly because summers here are triple digits all season long, and it seems to run better than using 5w-30. The owners manual has a small chart showing 5w-30 preferred for lower than 100F temps, and 10w-30 can be used for temps above 0F...
Here's their wording directly under the chart:
"SAE 5W-30 is the best choice for your vehicle, for good fuel economy and good starting in cold weather.
If you use SAE 10W-30 engine oil in extremely low temperatures, the engine may become difficult to start, so SAE 5W-30 engine oil is recommended."
1997 4Runner Limited 4WD w/factory RR Diff Lock (4.30:1), Blue Wire Mod, KYB monomax & 'tall' coils, Falken Wildpeak AT3W 265/75 on 16x8" Raceline 887's(+1" spacing), K&N CAI, Tru-cool 4589 bypass, TB gasket mod, OEM sport hood, Satoshi style grill, steel front skid and more
"Do not go where the path may lead, go instead where there is no path and blaze a trail."
11-02-2013, 05:08 PM
Real Name: Robert
Real Name: Robert
I put canola oil in mine.
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
11-02-2013, 09:46 PM
Any 5w30 you like will be fine.. it's more important to use a good filter. Oem , wix pureone Mobil 1
The filter is where it's at
99 4runner highlander
285/75/16 kumho kl 61
tundra coils
LC 8wraps
5100s
11-02-2013, 10:00 PM
Can you show us the used oil analysis?
11-03-2013, 12:06 AM
Any synthetic
1998 4runner SR5 V6 4x4 Anthracite Metallic 191K
2000 Land Cruiser Limited V8 134K
1995 VW Jetta 2.0L 281K
11-03-2013, 12:12 AM
Butter. Runs real smoove.
