Old 10-12-2020, 10:46 AM #1
blaze17's Avatar
blaze17 blaze17 is offline
blaze17 is on a distinguished road
blaze17's Avatar
Pulling intake. What all should I do while I'm in there?
Time to replace the knock sensors and wiring harness. What else should be done or replaced while the intake is off? I'm also way over due for a timing belt and associated parts. Would it save any labor to do that at the same time?
2000 Limited auto with e-locker
OME 2890 rear springs/Monroe Quick Struts up front
290K
blaze17 is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 11:04 AM #2
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I would recommend doing all the things from the list below when you are in there.
Valve Cover Gaskets
All Vacuum Lines
Spark Plugs
Spark Plug Wires
Spark Plug Boots
Coolant Flush
Throttle Body/IAC clean
Replace crappy wire loom with HeatProof Tape.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 11:13 AM #3
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
all of the above already mentioned +
-PCV valve, hose and grommet
-intake plenum gasket
-LCE engineering O shaped throttle body gasket, TRD O-shaped, or new OEM D shaped (either, doesnt matter, these 3 are quality, and the LCE may be best).
-Don't forget a new IAC gasket if you clean the IAC. might as well go new if you're already at it
Also, doing your timing belt and associated parts is a separate job, and doesn't require intake removal. It will not save you any labor.
If you have leaky valve covers, this is certainly the best time to knock those out too. Intake must come off, and it'll save you some labor.
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 03:13 PM #4
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Valve cover gasket for sure (intake HAS to come off), and the other stuff mentioned on top already.
Old 10-12-2020, 03:22 PM #5
blaze17's Avatar
blaze17's Avatar
Well it looks like I have quite a project. Thanks guys.
290K
Old 10-12-2020, 07:30 PM #6
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Good luck to you! I battled a knock sensor gremlin for months, see my old thread for details. My advice: confirm continuity every way you can before installation, and use Denso products. Many people (including myself) have used the older Matsu style sensors only to experience P0325/P0330 promptly after - even putting out MUCH sloppier waveforms when hooked up to an oscope. I suspect the major difference in quality is why Toyota themselves made the switch
Pretty much everything that can be knocked out at the same time has already been listed above, and is practically everything I did during my debacle. It's really not as much work as it sounds, nearly all of what's listed is dead easy if just a little tedious
I personally recommend the Teflon O-shaped "heat-sinking" gasket from LCE. I spoke with their customer service on it's durability, and the guy I spoke with told me he's personally re-used his 5 times and it still seals great. As for other gaskets, I recommend buying them online - not sure about your area, but stores around me charge like $160 for the plenum/manifold set, but online it's like $40. Absolutely absurd
Old 10-12-2020, 08:23 PM #7
Boss.man Boss.man is offline
Boss.man is on a distinguished road
Definitely all the above. But that makes for one heck of a day. Or two. Lol.
Boss.man is offline   Reply With QuoteReply With Quote
Old 10-12-2020, 10:52 PM #8
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Is there a list of vacuum hoses? Sounds like I should do this to with my valve cover gaskets
Old 10-12-2020, 11:28 PM #9
marcus clarkus's Avatar
marcus clarkus marcus clarkus is offline
marcus clarkus is on a distinguished road
You have to remove the fuel rail. I replaced the banjo bolt washers (PN 90430120260) to make sure they sealed well. I also replaced the little o-ring for the Fuel Pressure regulator since I removed that as part of removing the fuel rail. I had some spare injector o-rings as well.
I’ll second the IAC gasket comments (I used OEM) and I used Fel Pro MS 95898 plenum and manifold gaskets which are fine.
I rewrapped my engine harness too since the plastic was crumbling to bits. I used some sort of silicone tape and it’s been holding up.
1999 Toyota 4Runner SR5 V6 4x4 5spd - 317k miles as of Feb 2024
3D Printed SR5 Mudflaps
FS: 3D Printed Outlet Covers - Convert rear ashtray to 12V/USB outlets
marcus clarkus is offline   Reply With QuoteReply With Quote
Old 10-13-2020, 09:42 AM #10
I also recommend this gasket. I use it with no issues, high quality piece that removes the "D" Shaped gasket at a cheaper price than a TRD O-shaped one
belt , intake , pulling , time , timing
FS: 3rd Gen Upper Intake Manifold Plenum & Lower Intake Runners - Cen TX; Will Ship SURF RUNNER For Sale: T4R Items 19 01-10-2016 12:22 AM
Water in intake... throttle body or intake gasket? a_young240 3rd gen T4Rs 10 08-25-2013 01:41 PM
Cold air intake with battery/intake swap on budget! Thurlo76 Classic T4Rs 13 05-24-2012 01:06 AM
Air intake crap - Kamotors Performance Carbon Fiber Filter 3" Cold Air Intake BMW VW Singtoe 3rd gen T4Rs 11 01-13-2012 06:51 PM
