Old 10-13-2020, 02:01 PM #16
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Originally Posted by Mark_BC View Post
I bypassed the radiator transmission cooler and put on an aftermarket one in front. It doesn't have as much cooling power but I don't have to worry about the milkshake. I monitor the temps on my scangauge and the high temp happens when you are crawling up a hill in the heat since there is little air flow. But just put it in low and hit the ECT button which seems to help it stay down. Keep in mind this is Canada, not Arizona heat.
Do you have any issues in the winter getting the transmission up to temperature? I bypassed mine but the coldest temperature I've ever put it in was 25 degrees, not exactly freezing.
326WHP 347TQ
Old 10-13-2020, 02:11 PM #17
4hashiro 4hashiro is offline
Real Name: Rico
4hashiro is on a distinguished road
Real Name: Rico
Prior to installing a new oem radiator I ran cooling system cleaner and distilled water and flushed every other day until I was satisfied(my cooling system was filthy at 225k when I bought it). That gave me more piece of mind installing the new radiator and not worrying about the milkshake. I ran my cooler in series with the radiator to avoid any warm up temp issues. And I also replaced the lbj's because the previous owner had just done it to sell the rig, but he had used aftermarket ones and I wasn't comfortable with that.
18 MGM TRDOR: ARB classic rack, C4 ladder/ Front - Toytec 3" Non adjustable, JBA uca, Toytec diff drop/ Rear - Toytec Aluma 2.0 shocks, Superflex HD coils, KDSS drop brackets/ Toytec 1" BL, SCS SR8 et-10 17x8.5, Toyo RT 315/70r17, BMC/ Pedal Commander, TRD CAI, URD Y pipe, Borla Type-S
00 ltd elocker(sold): F tundra 5100's eibach 620 R lc 7.5 wraps tokico blacks, 1" toytec bl, pro comp 69's yoko MT's 285/75r16, jba offroad uca, toytec diff drop, 231mm tbu
4hashiro is offline   Reply With QuoteReply With Quote
Old 10-13-2020, 06:04 PM #18
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
For the radiator, it's not just the pink milkshake that's a concern. The plastic tanks get very brittle with age and can literally disintegrate at a moment's notice.
I was once removing the upper radiator hose on my dad's '01 Camry, and the upper fitting simply came off with the hose as I was trying to twist it off, took almost no effort.
Bypassing the trans cooler would not address this concern. I always replace these radiators at 10 years or 100K.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 10-13-2020, 07:21 PM #19
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Just noticed this now (sorry to hijhack a thread). My 4Runner makes a small squeak when making a decent turn (and going through a speed bump). Is this a symptom of a bad ball joint. My rig has 220K on the original ball joints (i think).
I know I gave out advice, but now I hear a squeak when turning. It's small though.
How do i check for lower ball joint play?
Old 10-15-2020, 07:05 PM #20
thatoneguy's Avatar
thatoneguy thatoneguy is offline
thatoneguy has a spectacular aura about thatoneguy has a spectacular aura about thatoneguy has a spectacular aura about
thatoneguy's Avatar
Got my 4Runner back today. New OEM LBJ's are in.
Not sure if this would be pure placebo-effect, but to me it feels like it "drives tighter" or such. That realistic? My mechanic said they showed no signs of wear. He also said he owned a 3rd gen that went 300k on the originals.
2023 TRD Offroad Premium, nautical blue
Former: 1987 SR5 w/ SAS, 1999 Limited w/ e-locker
thatoneguy is offline   Reply With QuoteReply With Quote
Old 10-15-2020, 08:11 PM #21
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
The procedure involves jacks, blocks and a dial indicator. It's a pain and very hard to get good readings. Most of us will only be able to see gross slop. A LBJ at the limit will be very difficult to spot as the limit is no play.
This is the reason that it is generally recommended to replace them on a schedule. How much of a gambler are you?
FWIW, my original OEM LBJs had detectable play (and were replaced) at under 100,000 miles. I seem to be unusual in this as most go much higher, but again, how much you want to risk?
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 10-16-2020, 10:47 AM #22
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
LBJ Testing
Using the FSM procedure tells the whole story, I tweaked procedure for quick inspection a go-no go thing. Jack a tire off the ground don't need to remove tire, or lift both off ground by jacking from under front diff. Use pry bar in the right spot,
if you can see movement with the naked eye you are beyond needing LBJ's, max play is .020".
Old 10-16-2020, 12:34 PM #23
Real Name: Mark
Real Name: Mark
What MY was this with ?
96Red went many miles, 01 @198k naked eye test failed.
I wonder at times if Toyota around 99 or so changed the cast iron formula to get 3rd gens off the road or just saving dollars.
With you on risk factor, I Like the Runner getting hard to come by, don't want to deal with this on side of the road.
Old 10-16-2020, 03:24 PM #24
Kanoe's Avatar
Kanoe's Avatar
Very early 96 so not a lot of mileage but years.
The replacements are at 100,000 km and about 8 years and still look good. I'll change them out again in a few years, I have a spare set on hand.
-2001 Echo D.D.
Old 02-04-2024, 03:58 PM #25
mooremedia's Avatar
mooremedia mooremedia is offline
mooremedia is on a distinguished road
mooremedia's Avatar
Late to this thread, but will add:
I have a similar situation with my 2002 SR5 4wd. At 165k miles, I haven't been able to find out (via VIN search) if they LBJ's have been replaced when the recall was still active back then. They don't have much play. But yikes, those images of LBJ failures got me freaked out.
So I pulled the trigger and ordered all the parts to bring to my local shop. I went to Toyota Parts Factory - #1 Source for Genuine OEM Toyota Scion Parts & Accessories | Camelback Toyota Parts in Phoenix to get OEM parts.
Total for L and R ball joint which includes new nut and cotter pin, plus 8 new bolts came to: $295.85 which included state tax and shipping to Los Angeles.
Toyota PN Desc:
90119-10933 Bolt W Washer
43330-39585 Suspension Ball Joint (Right, Front, Lower)
43340-39465 Suspension Ball Joint (Left, Front, Lower)
These are for an '02 not sure if the part numbers are correct for similar years.
mooremedia is offline   Reply With QuoteReply With Quote
Old 02-04-2024, 06:17 PM #26
Real Name: Mark
Real Name: Mark
@mooremedia since shop doing the work, find a .2 fl oz tube of Loctite 271 or equivalent to go with the box of parts, mention it.
Been cases of bolts getting loose, some don't know some don't have it on hand some don't think of it.
Give em a hint.
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
ball , higher , joints , lower , replace
Lower ball joints atran27 4th Gen T4Rs 15 12-08-2020 04:26 PM
PA: 3rd Gen lower ball joints superex87 For Sale: Suspension/Wheels/Tires 6 01-05-2019 08:41 PM
---I will buy your old lower ball joints--- Z-4runner 3rd gen T4Rs 8 04-29-2016 10:56 PM
35's and lower ball joints - mileage/life? rideexileex 3rd gen T4Rs 6 08-06-2015 07:59 PM
Help with Lower Ball Joints... JustSomeName 4th Gen T4Rs 15 08-13-2012 03:12 PM
