Old 10-12-2020, 03:11 PM #1
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Rattle Sound problem when idling
Hey guys,
So i got an issue with possibly the exhaust system. When the truck is stationary, it starts to rattle. It's not very loud, but loud enough to be disturbed (especially in traffic). When popping it into neutral, the rattle just stops...?
I have heard that Catalytic Convertors go out often in this truck. Is this the case? I got 220K on the truck.
Old 10-12-2020, 03:47 PM #2
spartacus's Avatar
spartacus's Avatar
Originally Posted by FD7683 View Post
Hey guys,
Most probably could be one of' the heat sheilds. Does it matter if the the AC is running or not. Mine did it only when stationary and AC on. Use a rubber mallet and tap heat sheilds, muffler, skids etc and you should be able to tell the difference between the loose and tight.
Old 10-12-2020, 04:26 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Loose heatshields would be my guess. Especially if it's a factory cat. Those babies start to rattle in time.
You can check and verify the exhaust like the other user suggested as well as verify your exhaust pipe isnt touching a crossmember as well. I had my exhaust pipe occasionally touch the crossmember after all the cats. Boy was that rattle annoyong.. might as well verify all your exhaust clamps are good too.
Old 10-12-2020, 07:52 PM #4
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
When I first got my truck I had a rattling cat at idle and no matter how much I tinkered with the heat shields it wouldn't go away and I was afraid the honeycomb started to shatter. Turns out it was a small, notecard sized plate that was tack welded right behind the cat, on top of the exhaust (I assume it was an ID plate of sorts) and one of the welds broke off. Ripped it off and never heard it again
A near dead cat will rattle almost constantly (especially on revs, as opposed to idle) and very obviously sounds like something getting blown and thrown around inside the exhaust - not a very consistent noise, in terms of how/when it starts to rattle. You would more than likely have a code thrown for the cat or O2 sensors, too
Old 10-13-2020, 07:22 PM #5
I will be checking my shields. Thanks guys for the help!
Old 10-13-2020, 10:56 PM #6
ArmArak's Avatar
ArmArak ArmArak is offline
ArmArak will become famous soon enough ArmArak will become famous soon enough
ArmArak's Avatar
I had the same issue, for me it was the small heat shield under the passenger side front door. It had two holes that were missing bolts so I just stuck two bolts and their respective nuts to clamp it back into place. Easy fix.
Good Luck!
ArmArak is offline   Reply With QuoteReply With Quote
Old 10-14-2020, 05:07 PM #7
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Mine used to rattle in gear, usually most annoying when in fast food lines.
Turned out to be loose bolts on the transfer case dampner. Snugged up and no more rattle. Luck.
Old 10-15-2020, 02:45 AM #8
JUICE222 JUICE222 is offline
JUICE222 is on a distinguished road
My 4runner has an annoying rattle only when pressing on the accelerator. It seems to be coming from underneath the truck. Going to check some of the things you guys suggested. Thanks for all the tips.
JUICE222 is offline   Reply With QuoteReply With Quote
Old 10-21-2020, 03:28 PM #9
98rustylimited 98rustylimited is offline
98rustylimited is on a distinguished road
I've been having the same problem with mine, just bought my 3rd gen a few months ago. I found my rattle was the very end of the exhaust pipe hitting the trailer hitch. a simple kick of the exhaust pipe while it was idling made the rattle go away. My noise would only come up at stop lights and would disappear whenever i drove or took it out of gear.
98rustylimited is offline   Reply With QuoteReply With Quote
loud , popping , rattle , traffic , truck
Engine knock,rattle, not idling... Upchk 4th Gen T4Rs 7 03-10-2016 05:30 PM
low idling problem pinchiab 3rd gen T4Rs 1 02-09-2014 03:55 PM
Idling problem 3.4 97 MattToyoFreak28 3rd gen T4Rs 7 01-22-2014 06:02 PM
Rough idling problem CG Choppers Problems & Warranty Issues 0 02-16-2008 12:13 AM
Odd sound while idling? summit21 4th Gen T4Rs 1 12-06-2006 06:18 PM
