11-11-2011, 05:34 PM
My homemade Stealthbox
$599 for a JL Audio Stealthbox??? I decided that I loved the look and space saving idea but I couldn't justify that much $ for a box. So I figured why not build one. Total cost $120! 1/2 " sheet of MDF $40, Alpine 1043 10" sub $65, speaker terminal $5, and $10 in glue, screws, and polyfil. I was fortunate to have my amp already which puts 150 watts out and it sounds AWESOME. The airspace required for a sealed box with this sub is .75 cu/ft - 1.5 cu/ft. Mine clocks in at .79 cu/ft. Drilled a hole through the box and wheel well for a 6" nut/bolt/lock washer setup so its nice and secure. Thinking about tan carpet but haven't decided yet because its covered by the cargo cover anyway. Ok maybe its not as "pretty" as the stealthbox, but for a $480 savings I think I can live with that... HA. Hope you guys dig it!
11-11-2011, 06:01 PM
I like it!! good work!!!
www.chitown4x4.com
11-11-2011, 06:04 PM
Great work, If you made that 1-2"s lower then the cargo cover looks like it would fit over it and make it more stealthy
戦争イーグル
Cory J
Wheel converter,
11-11-2011, 07:27 PM
Real Name: Zach
Real Name: Zach
looks good I wanna eventually do something like this in mine. Now, it looks like you dont need that cargo cover....I can take it off your hands for ya
My Build Thread
1999 Highlander Edition w/ Factory E-Locker: Alarm/remote start, FN 5 star wheels, 285/75/16 Duratracs, King 2.4 Ext Travel C/Os, LC shocks/8 wraps, 1" Diff drop, Airaid Intake, Dual B&M 70264's, Satoshi grille, 01 Tails, shackles, Rear diff breather extension, Blue wire mod,Taco whip antenna, Window tint, Bi-xenon Morimoto Mini Stage III projectors, 231mm Tundra Brake Upgrade, Interior LEDs.
11-11-2011, 07:51 PM
Actually, the cover is level with the top of the box. Pulls right over it. Kind of deceptive looking at that angle but I made sure it pulled out a couple times before the final assembly.
11-11-2011, 08:41 PM
looks really sweet! this is going to be my next project
do you have a picture showing how you fastened it to the base?
2000 Limited, 2021 SR5
11-11-2011, 08:45 PM
looks great! i did something similar but with a 6in sub, .25^3ft box and 150w amp. works great and its perfect for my taste. i think i was in for <$180 including amp and speaker
2002 SR5 4WD
deckplate + ISR, Airlift 1000, OME 881/890, Goodyear Wrangler Duratrac 265/75/16C
Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims - Stubbs Welding HD-SKO sliders.
11-12-2011, 12:00 AM
Jungos, I added pics of the process. Basically I drilled a 3/8" hole through the diagonal lower box transition all the way through the wheel well. Pushed a 5" bolt through the box then put a flat washer, lock washer and nut on the back to lock it in place on the box. Then put the whole thing through the wheel well with another flat washer, lock washer, then nut. Extra wing nut just in case. A light spray w black paint on the end in the wheel well above the tire just to hide it a bit.
11-12-2011, 12:18 AM
I've seen this on Cardomain before....I think it was slightly different though...but if I ever rocked a sub...I'd try an install like this! Virtually no cargo space lost....and looks almost factory!
1998 4Runner SR5, ISR and Deckplate Mods, Painted Intake Manifold, TRD Tundra Struts, Diff Drop, LC 8 Wraps w/ Skyjacker shocks, Panhard Drop Bracket, Rear Tire Carrier, Maxxis Bighorns, Procomp Wheels, Custom Front Valance, Sport Edition Skidplate, Upgraded Exterior lighting
11-12-2011, 12:47 AM
Real Name: Evan
Real Name: Evan
I think the one in the cargo compartment would look 100x better if it were wrapped in vinyl. The texture of the carpet doesn't look right on a plastic interior panel.
The Stealthbox is nice, but not $600 nice lol. That's highway robbery.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
11-12-2011, 01:09 PM
How much would you charge to make One for me?
11-12-2011, 06:53 PM
no idea. it took me a long time to get all the dimensions down right and figure out a way to mount it securely. i dont think i want to build another. lol
2002 SR5 4WD
11-12-2011, 06:59 PM
My stealth box haha.
11-14-2011, 09:31 AM
I never thought that the Stealhbox was horribly out of line...
Since I build stuff all the time, many don't realize what goes into something like that... and im talking one offs here, not high volume like the box, but here it goes... just so you all understand it!
1/2 Sheet of MDF - $20
Box Of Screws - $5
3 small tubes of liquid nails - $15
Gallon of Resin and extra hardener - $50
Gallon of Dura Glass - $50
Gallon of Bondo - $25
Terminal Cups - $5
Hardware for mounting subwoofer - $5
1 yard of stretch fleece - $10
1 yard of color matched carpet or vinyl - $25
Subwoofer - $200
Thats $410 to make that enclosure and put a sub in it.... Now mind you, if I upped my MDF material I could probably make 2-3 of the enclosures with this material, but if you wanted to make one, this is about what you would run into. So don't get too bent out of shape with the JL box prices.
www.chitown4x4.com
11-14-2011, 10:08 AM
Well you are really amazing,Your work is different and I like it so much.
Saturn
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
