Old 10-15-2020, 09:00 PM #31
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
Originally Posted by WeakSauz View Post
My airbag light on the tachometer has been blinking for the last 20,000 miles. I need to actually diagnose / chase it down to figure it out.
How'd you determine yours was an open circuit? Is there a way to read an airbag code?
If you can't tell, airbags are far from my interest area.
In your engine bay diagnostic port take a wire to use as a jump wire and plug into AB and TC port. Turn key on to ACC position. Your cruise control light will have a seizure. Your air bag light will go on for 6 seconds doing it's normal self check. It will then do 1 second blinks for however many times, rest 2.5 seconds, then blink 1 second interval again, then 4 seconds off. This tells you your two digit code, then you need to look that code up.
Example: blink 6 times, off 2.5 seconds, blink 4 times, off 4 seconds is code 64.
You may have more then one code. So after the 4 seconds off it may start the second code...
Example: blink 6 times, off 2.5 seconds, blink 4 times, off 4 seconds, blink 3 times, off 2.5, blink 2 times, off 4 seconds. Codes 64 and 32
So watch it until the first code repeats...
Once you start attempting to fix...disconnect negative terminal so you don't cause your bags to deploy while checking connections.
Once you fix the problem you need to clear the code. IT WILL NOT CLEAR ON ITS OWN!
Obd2 from dealer is best...make a friend in the repair section, bring him beer and hope he doesn't charge you...
Other wise with key in acc position using 2 long wire. Plug one into tc port and one into ab port. Starting with the tc port alternate grounding them on a body ground for 1 second intervals allowing .2 seconds between switching. Tc needs to be grounded 3 times and on the last one hold for a few seconds.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 10-15-2020, 09:12 PM #32
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
Originally Posted by phattyduck View Post
All you need to do to fix that is clean it.
Pull it all the way out and clamp, scrub with an all-purpose cleaner, let it FULLY dry and you are done. It'll work like the day it was new.
It was also freyed in a couple spots, so beyond just cleaning. I should have mentioned that...Add the fact that this '98 4runner is designated as my kids 1st car, so I wanted a new one for cheap peace of mind.
I've been through the cleaning routine and had some success with the retractor spring in our '97 years ago. Still on original seatbelts (and airbags!) in that one.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
Old 10-15-2020, 10:59 PM #33
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Been interesting.
Seat belts no problem we good.
Airbags we roll till there aren't any good ones, go old school.
What the hell I drove 24 yr before they were mandated.
Old 10-15-2020, 11:49 PM #34
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Originally Posted by 96RedRunner View Post
Been interesting.
I remember riding in cars before BELTS were mandated. My mother's first car with belts was a '74 Mercedes. She never used them. One day we (her kids) made her put it on. Over objection she did. Once we arrived, she had no idea how to get it off. We all got out of the car and left her stuck there.
My Backyard Frame Swap
Old 10-16-2020, 10:51 AM #35
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Some classic cars don't even have seat belts. While Air bags were not required until 1990. Just how it was.
From the consensus of this thread it looks like the Air Bags are non issue no repair no replace unless the system has issues then it should be repaired.
Also the Air bag system is just like the ABS its older system that requires the diagnostic engine connector to get the error codes out of the system.
Old 10-16-2020, 10:56 AM #36
Real Name: Mark
Real Name: Mark
That's funny n mean lol at the same time, my bro n sis n I would have needed to spend a night or two at friend's.
Belt latch's back then were not as intuitive as they are now for sure.
Old 10-16-2020, 12:22 PM #37
Been interesting.
I STILL drive a no-airbag, no-abs vehicle regularly...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-16-2020, 12:56 PM #38
Real Name: Mark
Real Name: Mark
I like that would also if I had one from that era, can live with or without nanny stuff.
Had 68 MG Midget 4-5 yr old as DD no way in hell would I do it now, steel cocoon nice.
Old 10-16-2020, 01:02 PM #39
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I have 2 classic cars. So I do on occasion drive rides with only lap belts.
Old 10-16-2020, 01:12 PM #40
Real Name: Mark
Real Name: Mark
I take back not having of the era sorta, I ride a HD Wideglide a lot.
Old 10-21-2020, 09:36 PM #41
Satter's Avatar
Satter Satter is offline
Satter is on a distinguished road
Satter's Avatar
Update
So the service advisor from Toyota of Boerne got back to. She said
“ I have spoke with several technicians and parts department employees and they all say not to replace the air bag. There is no expiration for the inflator module”
So good new I suppose.
'98 4Runner Ltd 4WD.
A Ford might get you from point A to point B. But a Toyota will always get you home.
Satter is offline   Reply With QuoteReply With Quote
4runner , airbags , original , replaced
Replaced under warranty, what have you had repaired/replaced? WandaRunner 5th gen T4Rs 40 12-29-2018 08:07 PM
Airbags t4rnoob 3rd gen T4Rs 30 09-14-2015 03:15 PM
airbags and PSI kitesurf 5th gen T4Rs 5 04-23-2013 08:08 AM
Side Airbags? Texas05SE 4th Gen T4Rs 4 04-03-2010 08:49 AM
Airbags 4BangerRunner 3rd gen T4Rs 3 07-18-2008 06:31 PM
