08-22-2017, 11:20 AM
How frame repair should look
This is not my 4runner, and it is not me who did the work. It is a local friend in NJ. Who welds and fabricates for a living. If anyone needs anything welded or fixed in the NJ area. He's a good welder to go to. There have been few photos of guys getting a bad job done on fixing a frame.
PM for his name if anyone in the northeast needs stuff like this done
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
08-22-2017, 01:19 PM
Does anything get sprayed inside of that piece to keep it from rusting inside?
08-22-2017, 01:38 PM
Real Name: 3 Bears
Real Name: 3 Bears
I wonder if this would be worth doing even though I don't live in the rust belt, I mean the spray thing
08-22-2017, 01:46 PM
Why not ? Water, moisture can still happen. Especially if you off roadand do water and mud crossings.
08-22-2017, 02:27 PM
Real Name: 3 Bears
Real Name: 3 Bears
yes I do, guess I have another project coming toward me
08-22-2017, 02:31 PM
Real Name: Mark
Real Name: Mark
For the cost, it's good insurance where ever you live!
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
08-22-2017, 02:56 PM
Get a gallon of fluid film. Get a cheap brush and gloves. And brush fluid film on the outside of the frame and under body of the vehicle. That's what I do.
08-22-2017, 03:08 PM
And some in spray cans to spray inside the frame through every hole. After a good hose out of course.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
08-22-2017, 03:22 PM
Are frame repairs like this expensive?
I have a 97 limited needing about 1 foot of frame repaired behind the rear axel on the driver's side. Frame is completely rotted through where snow/salt must have accumulated against the spare tire. The rest of the frame is good with surface rust.
Is something like the original pic going to cost around $200, $800, maybe more?
A general idea of cost would be greatly appreciated.
08-22-2017, 08:07 PM
He said that, was $500
11-29-2020, 06:57 PM
Can you send me your friends name and number I have a Tacoma that need a frame repair. Thanks
11-29-2020, 07:21 PM
Wow, that looks like 1/4" plate and continuos welds., bit much IMO, and those vertical welds are not advised although common on even factory frames and slider installs, fish plating <> is safer as it doesn't cause a vertical crack later on in life.
