Old 10-15-2020, 09:38 AM #1
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Valve Cover Gaskets info in FSM?
I've been getting everything ready for my upcoming valve cover gasket replacement job and I wanted to go ahead and print out the pages from the factory service manual so that way I had all the torque specs and everything.
well I spent a lot of time looking around, a lot of time searching, and a lot of time looking on the web and I can't for the life of me figure out which section has the information on the valve covers. The only thing I know is that people on the valve covers themselves is extremely low and specific, just this is so critical I definitely want to make sure I've got the right information.
Does anyone know where in the FSM it details the valve covers?
Old 10-15-2020, 09:52 AM #2
heat's Avatar
heat heat is online now
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
It's listed with cylinder head R&R.
Valve Cover Gaskets info in FSM?-vc_gaskets-jpg
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is online now   Reply With QuoteReply With Quote
Old 10-15-2020, 10:15 AM #3
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
It's not all listed in one neat little area in the FSM. You have to search through the EM (Engine Mechanical) pages to find all the related pages or you could just use our video as a tutorial because we list all the torque specs you'll need for the job.
Old 10-15-2020, 10:33 PM #4
jross20's Avatar
jross20's Avatar
Well damn I would have never looked in the cylinder head area... Haha.
Tim I think I'll watch your video a couple times and try to memorize the data and write it down. when I'm done I'll try to put it into a nice document and maybe upload it for others
Thanks guys!
Old 10-16-2020, 08:50 AM #5
heat's Avatar
heat's Avatar
Or you could just reference the thread ramonortiz55 put together a while back.
Replacing Valve Cover Gaskets - A True Write Up - **PICTURES**
Old 10-16-2020, 09:07 AM #6
Kbuch1's Avatar
Kbuch1 Kbuch1 is offline
Real Name: Kevin
Kbuch1 is on a distinguished road
Kbuch1's Avatar
Real Name: Kevin
Watch Tim’s videos and it will answer 99.9% of any questions or details related to the VCG or other projects he has documented.
I search his YouTube site for whatever topic as a first step on all my projects.
It’s pretty simple to do. Good luck.
Kbuch1 is offline   Reply With QuoteReply With Quote
Old 10-16-2020, 09:16 AM #7
Kbuch1's Avatar
Real Name: Kevin
Kbuch1's Avatar
Real Name: Kevin
Ramonortiz55’s writeup is a solid reference for this project as well.
Old 10-16-2020, 10:07 AM #8
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Thanks guys!
If you need more detail of how to get the plenums on and all the vacuum hoses and electrical connector connected, our fuel injector video might be a good one to consult too.
Old 10-16-2020, 12:26 PM #9
jross20's Avatar
jross20's Avatar
I'm actually doing the injectors at the same time!
Is there anything else you recommend doing while I'm in there?
Old 10-16-2020, 05:28 PM #10
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Well, if you were considering getting your fuel injectors refurbished or replaced by some refurbished ones at some point, this would be the time to do it. Motorwest Performance which we link in the Injector Video is a solid choice for injectors. Other than that, there is the knock sensors which are under the intake manifold that can go bad but I would probably wait until you have an issue with one of your knock sensors. Refurbished fuel injectors do make a difference with the performance of your motor so it's not a bad idea to do but it will cost you some extra coin that maybe you don't want to spend money on right now.
Old 10-17-2020, 12:19 AM #11
jross20's Avatar
jross20's Avatar
Ah I actually already aquired some from the guy you recommended in another thread. Motorwest that is.
I'm actually curious about any kind of performance increase even though it's not the goal period definitely will be a nice bonus. I recently swapped out my worn out spark plugs for the nkg's from Toyota and holy crap I'm up to 19.75 mpg now! So I'm wondering if swapping the injectors will push her to 20.
If not though I'll still take any power increase or at least a smoother engine
covers , fsm , lot , time , valve
Valve cover gaskets AntleredRuin 3rd gen T4Rs 3 11-22-2017 02:09 PM
Any other gaskets I should replace when doing to valve cover gaskets? michaelreed 4th Gen T4Rs 0 07-23-2013 09:08 AM
Valve cover gaskets SJC 3rd gen T4Rs 16 08-02-2012 12:29 AM
Valve Cover Gaskets DeeDub 3rd gen T4Rs 10 10-12-2010 12:53 PM
valve cover gaskets patgensel 4th Gen T4Rs 1 11-12-2006 08:40 PM
