Originally Posted by nobb
My 3rd gen is lifted 3 inches with a slight rake to the front so I'm trying to adjust the headlights higher. However I keep turning the adjustment screw but it doesn't seem like anything happens so I'm guessing the plastic tabs have worn out. Anyone run into this or have any thoughts?
Thanks.
Yup. Take a look at this post here:
https://www.toyota-4runner.org/2525527-post209.html
It's not that they wear out, but the collar that holds the head of the screw breaks, so the screw moves in and out but the light doesn't move. You can't get the part, so either you do a transplant from a junkyard or get a new light.
I had a MacGuyver work around temp fix. I was able to stick a rubber ball between the light and the can that kept the screw head in the tab. YMMV on that one.
My Backyard Frame Swap
