Old 10-19-2020, 08:45 AM #16
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
- Sound Dampening material in the doors, entire floor board, and rear cargo area/ wheel wells
- Alpine Double Din with Apple Car Play, backup camera and hands free calls
- LED lighting in interior
- Welding the slip joint and shimming the tilt ball in my 240k Mile steering shaft made a major difference for me in drive-ability (not recommended if safety is of utmost importance to you, or if other fam members drive your rig).
- If you're lifted, an aftermarket set of UCAs to get alignment within spec. I was shocked at the improvement when adding mine
- Arguable point, and only my opinion. But, removing the front sway bar made the truck drive much smoother, absorb bumps in the road without as much drama, improved offroad articulation, etc. I don't notice an excessive amount of body roll. I have yet to experience a single downside to removing it, and it's been off for 12k miles. However, literally every bushing in the front end is new, along with new oem steering rack, LBJs, etc (i think removing the swaybar on a worn out 4runner may net you some negative results)
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 12:19 PM #17
JLStout JLStout is offline
JLStout is on a distinguished road
Originally Posted by nobb View Post
Oh man, I do wonder what these trucks would ride like with brand new bushings. Are you sure they weren't hard to do? The LCA seems like a b*tch to do after all these years. Definitely would need to get torched out, and possibly a hydraulic press. I hate suspension work in general.
Just did mine last year. Fire pit. Put them in for a while and melted the old out.
JLStout is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 12:45 PM #18
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
I just used the oem bottle jack inside the lca and they popped right out. Make sure you put a ratchet strap around the lca pretty tight so it doesn’t bend though.
Tundra brakes were definitely a nice feeling upgrade, the old brakes felt like they were a bit overloaded with all the extra weight/larger tires.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 01:21 PM #19
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
one of the first things I did was cleaning the MAF and throttle body ( correctly ) and setting the cables for accelerator and kick down correct helps a lot ( often worn and sloppy and out of adjustment). Change out all fluids and filters, plugs and pvc..
Ive done lots of other things too, that too me help a lot in reliability and drivability ( see sig)
Starting later today, upper ball joints, upper control arm bushings, tundra and billies up front and FJ springs and tokico in back, and all the extra steps mods required for the lift.
At least thats the plan,
Old 10-20-2020, 02:06 AM #20
itsgabriel's Avatar
itsgabriel itsgabriel is offline
itsgabriel is on a distinguished road
itsgabriel's Avatar
Looking at upgrading my head unit in my 99' soon. Which Alpine model did you go with?
itsgabriel is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 09:47 AM #21
Mine is an older model (ILX207) which I picked up used from a forum member here. It's awesome, but I am sure there are some nicer ones out on the market by now. Functionally, as long as it had carplay, I didnt care
Old 10-20-2020, 11:32 AM #22
Chris_Overland's Avatar
Chris_Overland Chris_Overland is offline
Chris_Overland will become famous soon enough
Seat warmers from amazon, my buns are loving them.
Amazon.com: KINGLETING Heated Seat Cushion with Intelligent Temperature Controller.(Black): Automotive
1999 Imperial Jade Mica Limited
Bilstein 5100 & OME 881/891
SpyderTrax 1.5 spacers
Tundra brake upgrade
238,000 and still kickin
Chris_Overland is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 01:36 PM #23
Real Name: 3 Bears
Real Name: 3 Bears
Originally Posted by Chris_Overland View Post
might have to try that brand, the one I got last year, got in october , made it to january and slid all over the place....comfier...or some brand like that I think.
Old 11-01-2020, 09:45 PM #24
JohnOfTheJungle JohnOfTheJungle is offline
JohnOfTheJungle will become famous soon enough
I rigged up some eBay special seat heaters a few weeks ago, put them in when I replaced my seat covers.
With that install I wired up a blue sea fusebox in the passenger footwell and used the cig lighter 12v to send the signal when the car is on so they only activate when the car is on. For the switches I cut holes in the cubby below the ashtray and hooked them up there.
The look is totally stealth and they work pretty well. It’s a little more work but having them inside the seats is great.
1997 Limited 4x4 3.4l 199k E-locker Blue Wire Mod | 255/85 r16 Maxxis Bighorn MT - LX450 9 wrap + Tokico black rear | Front: 2.5" King Coilover set @ 2" lift | True North Fab Front Bumper + Warn m8000 + Baja Designs Squadron Sport | Custom Sliders | NguyenWorks Rear Bumper + Tire Swingout
JohnOfTheJungle is offline   Reply With QuoteReply With Quote
3rd , driveability/comfort , favorite , gen , mods
favorite interior mods dcarp444 4th Gen T4Rs 58 11-10-2023 07:37 PM
Favorite mods zopperman General Discussions 17 12-23-2013 03:05 PM
Highway comfort & touring mods. Please chime in. MICA4R 4th Gen T4Rs 4 05-26-2012 04:19 PM
What has been your top 5 favorite mods gray street 5th gen T4Rs 14 04-16-2012 10:33 AM
Driveability snap2it66 3rd gen T4Rs 14 01-27-2012 02:31 PM
