Old 10-19-2020, 02:11 PM #16
Fiffa's Avatar
Fiffa Fiffa is offline
Fiffa will become famous soon enough Fiffa will become famous soon enough
Fiffa's Avatar
Originally Posted by Boognish_Forever View Post
I was thinking about doing this. That would suck if it's a blown head gasket.
This is where my mind initially went. Although a little bit different of a powerplant, my Honda Ruckus did the same exact thing (temp rise and bubbles every 2-4 seconds in the coolant) when I rebuilt it because I wasn't torqueing the head bolts properly due to a wrench that needed to be calibrated. Got a new wrench, redid the gasket for the 4th time, and every was solved.
Fiffa is offline   Reply With QuoteReply With Quote
Old 10-31-2020, 02:30 AM #17
thor999 thor999 is offline
thor999 is on a distinguished road
New radiator, new fan clutch, new thermostat, external trans cooler. It is a MUST on these vehicles. ESPECIALLY if you want to go crawling in the desert. Hell, even after that, I still see my temps getting close to dangerous wheeling in Colorado in the middle of winter.
2001 SR5 4x4
thor999 is offline   Reply With QuoteReply With Quote
Old 10-31-2020, 09:17 AM #18
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Screams for 30 seconds driving or idling?
To backup what 19963.4lsr5 said. On first cold start for 30 sec or so mine is locked up moving air, this easiest time to hear the difference. Say engine is warmed to normal op temp, open hood turn engine off fan should stop rather quick, guesstimate 5-10 sec.
Old 11-01-2020, 09:54 PM #19
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Yeah I overheated climbing a grade in the snow once. I was completely baffled as to what was going on until I looked at the gauge since I figured the cold air would be enough to cool it off. Not when going 10 MPH thouhg!
326WHP 347TQ
Old 11-02-2020, 12:13 AM #20
Boognish_Forever's Avatar
Boognish_Forever Boognish_Forever is offline
Boognish_Forever is on a distinguished road
This makes me feel somewhat better being I was crawling for hours.
Does anyone know what temp the A/T temp light comes on?
Boognish_Forever is offline   Reply With QuoteReply With Quote
Old 11-02-2020, 01:36 AM #21
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
When its just about too late, 300F.
There s/b plenty of air being pulled even with a/c on, idling for hours or slow speed wheeling. There is something wrong, most likely a combination of aging fan clutch and failing radiator cap. Replace both with toyota stuff and it'll last a long time. Luck.
Old 11-02-2020, 03:28 AM #22
I just did the cap and will do the clutch fan in a month or so being I'm not doing any slow wheelie till next spring. I've been in stop and go traffic at 100 degree temps and my gauge would never go above half. I was seriously crawling at 5 to 10mph for a long time in 4low when it started to get warm.
Does your profile pic have anything to do with Willie Nelson, I can't tell if its him or not? I was listening to "I can get off on you" by Willie and Waylon while I was reading your comment.
Old 11-03-2020, 11:31 PM #23
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
If a vehicle is starting to get warm while crawling. I prefer to turn on the heater to max and raise the hood. This allows the vehicle to cool itself and prevent hotspots in the engine. When wheelin I also carry an infrared thermometer to verify Temps.
If your ATF reached 250 deg or higher change it. Even if recently changed.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 11-04-2020, 03:12 PM #24
jgue467's Avatar
jgue467's Avatar
Yes - its The Man! Hope we all last as long as he does....
bubbling , coolant , engine , half , temp
Stalling with high outdoor temps and slow speed shamrock94 3rd gen T4Rs 7 07-25-2018 02:53 PM
Clicking noise at slow speeds, need help!!! warriorwagner 3rd gen T4Rs 5 05-12-2015 01:22 AM
temps, air intake, and coolant temps on a stock runner the great him 3rd gen T4Rs 13 07-15-2014 10:18 PM
Transmission and Coolant Temps both rising... THatfield 3rd gen T4Rs 0 02-18-2014 05:13 PM
Surging at slow speeds!!! tomlexa1983 Classic T4Rs 10 04-01-2009 12:19 PM
