Originally Posted by Sarge92
I'd rather the 4600s because I don't want the lift from the 5100s and because they come front and rear i just need a spring that's strong and will work. I might just order a set of runner springs and pair them with the 4600 struts up front. I don't mind if the front dips a little lower than the rear, maybe it'll even out once its loaded up. What do you guys think about a set of 4600s, front and rear paired with runner springs up front and 906 springs in the rear?
I have a 99 so I have the tall springs but I have been running the setup mentioned plus air bags for four years. I haul 1000 lbs a few times a year and it does not hold up well unless I assist it with the bags. It would bottom out like the factory springs would. With 25 psi the truck rides level and smooth.
The 4600 have gone noticeably soft lately and the truck leans quite a bit on turns. I have always ran 4600's on all my rigs but they don't seems to be working well this time around.
I am considering the OME HD kit with bags.
If you frequently haul any type of heavy load then it is a good idea to assist the springs with air bags.
