Old 11-03-2020, 09:11 AM #31
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
may we know the brand and where you bought the bolts? did you install the LBJ dust covers?
Thanks
Originally Posted by theesotericone View Post
The Toyota bolts are 8.8 at best. As someone who's broken 7 of them I will tell you they are crap if you are pushing your rig. About 9 months ago I went to 10.9 M10-1.25x30mm hex head flange bolts. In that 9 months I haven't broken a single one. They are torqued to 60 ft/lbs and red loctited. My wheeling hasn't changed so it's a direct apples to apples comparison.
The Toyo bolts are fine for what the engineers have them designed for. Once you step up to 35's and big rocks they aren't even close to strong enough.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 11:03 AM #32
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
Thanks
McMaster-Carr
What LBJ dust cover? I've installed a lot of LBJ's and have never seen a dust cover.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 01:09 PM #33
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
like this
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 11-04-2020, 05:54 PM #34
Originally Posted by nissanh View Post
If you look at the lower ball joint mount to the spindle on newer models, there are just 2 bolts! I prefer 4 bolts like we have in the 3rd gen.
It the bolt is tight the shock absorber/coil spring will do the damping.
The new design doesn't put the lower ball joints (or bolts holding the ball joint) in tension. The two bolts are up-sized too, I believe.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-04-2020, 07:36 PM #35
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Yes, quite a bit bigger than the 4 used on our 4runners.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 11-05-2020, 08:05 PM #36
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Is it best to stay with the older style, or buy aftermarket ones? What type should I get? Zinc or...? I feel safer with Japanese steel if possible...
I believe someone said: 10.9 M10-1.25x30mm hex head flange bolt
Old 07-15-2022, 01:02 PM #37
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
We're running tests to gather quantitative data on these bolts (and others), to compare their strengths and appropriate torque levels. The results should answer all the questions and speculations raised in this thread - Everything you always wanted to know about LBJ bolts.
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 07-15-2022, 09:12 PM #38
scshack scshack is offline
scshack is on a distinguished road
I made the mistake of over torquing the LBJ bolts in my 2002 to 59 ft-lbs and after posting to the forum, folks suggested buying new bolts and torquing them to the correct 37 ft-lbf. I went this route since the bolts are designed to be "on-and-done", basically they were over stretched at 59 ft-lbs. Here is my original post.
Wheelin: 2002 SR5 3rd gen 4runner - 4wd w/ locker - ARB bumper, 10K Smittybilt winch, Victory 4x4 roof rack, All Pro Sliders, Tundra 5100, OME springs (3in lift), 31 in Kumo A/T tires (265/70/r16), Custom Rear Bumper, Full Body Armor (Front, transfer case, lower control arms, rear control arms, rear lower shocks, gas tank, rear diff) - 265K miles.
Daily: 2000 SR5 3rd gen 4runner - 4wd - Tundra 5100, OME springs (3in lift), 32 in Falken Wildpeak AT3W (275/70/r16) - 245K miles
scshack is offline   Reply With QuoteReply With Quote
Old 07-15-2022, 09:47 PM #39
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
I wonder if the lower torque for the 2001 2002 is so the bolts dont tear the dust covers. I briefly had a 2001, replaced the LBJ's with the old style higher torque bolts. Someone had done this car b4 as neither one had the dust covers but had the newer style bolts.
will be interesting to see what spiker tests show
and of course I have read threads saying dont reuse the bolts....and threads where people do reuse with no issue...so lots of questions on that....reuse or new....I go new and only use yota LBj's and bolts
the lbj is one thing about 3rd gens that make me nervous....poor design by yota
Old 07-16-2022, 10:41 AM #40
official vendor
official vendor
I think the bolts are actually nowhere near failure even at 59 ft-lbs, I think that is one of the common myths that I plan to bust (or to confirm, I am open to new data).
BTW, I see that you applied loctite to the bolts during installation. While a good idea, loctite lubricates the threads and may cause a higher installation preload than you would get with dry threads - so that may contribute to damaging or breaking the bolts. That will be part of our testing as well.
1996-2000 , bolts , style , torque , values
Poll: Broken lower balljoint angus 3rd gen T4Rs 26 05-05-2015 06:24 PM
LBJ - manual shows 2 different torque values Ghostrider 3rd gen T4Rs 3 10-20-2014 01:54 PM
Stuck lower balljoint cj80cruiser 3rd gen T4Rs 26 11-09-2012 01:19 PM
lower balljoint needs replacing - what tools are needed Surf_MoFo 3rd gen T4Rs 4 04-08-2009 02:08 PM
Diff drain & fill plugs torque values kup1236 Maintenance/Detailing 1 12-05-2005 09:21 AM
