Old 10-22-2020, 04:15 PM #1
tbryanh tbryanh is offline
tbryanh is on a distinguished road
Rear Springs: Installing 99 Talls Into a 97. Rubber Bump Stops?
Plenty of info out there on how to install rear springs, but not seeing anything about the rubber bump stops.
My 2000 has cone-shaped rubber bump stops inside the rear coils, but my 1997 does not. I want to put the 1999 tall coils into the 1997.
What would it take to add the bump stops to the 1997, or should I forget about doing that?
1997 2WD Limited. 2000 2WD SR5. 2000 2WD Limited.
tbryanh is offline   Reply With QuoteReply With Quote
Old 10-22-2020, 05:27 PM #2
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
They just fit right on top of the springs. They are as easy to put in as it is to swap the springs. They’ll gain you 1/4 inch in the rear too.
Older runners didn’t come with them but they fit right in.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 10-22-2020, 06:19 PM #3
Glad to know the top rubber just slides in with no mods needed to hold it in place. Camelback Toyota calls it the Spring Seat 48302-60051.
1998-2002 Toyota 4Runner Spring Seat 48302-60051 | Camelback Toyota Parts
There is also the Bumper 48306-60121 that goes in the bottom of the spring.
1998-2002 Toyota 4Runner Bumper 48306-60121 | Camelback Toyota Parts
Does the Bumper simply slide in to the bottom of the spring with no mods needed either?
Old 10-22-2020, 11:08 PM #4
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
There is only the rubber cone that sits on top of the rear coils, no lower seat, the coil simply rests on the steel perch on the axle tube. Both my MFG Date: 1997 sr5's had the cone until I put LC coils in the back.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 10-23-2020, 12:01 AM #5
stuckinthemud stuckinthemud is offline
stuckinthemud will become famous soon enough
My 97 has the bump stops on the top of the rear springs. Nothing but the steel seat on the bottom.
stuckinthemud is offline   Reply With QuoteReply With Quote
Old 10-23-2020, 10:35 AM #6
Yeah, I just took another look under my 2000. It appears there is just one rubber cone that feeds through the top of the spring and reaches down to where the bottom of the spring contacts the mount on the axle.
Not sure why Camelback shows the other rubber item. I will be going to the local Toyota dealer today to place an order.
Thanks for all the help. I feel I am prepared to deal with the parts department.
Old 10-23-2020, 10:58 AM #7
Quantumkiwi's Avatar
Quantumkiwi Quantumkiwi is offline
Quantumkiwi will become famous soon enough
To save you the exorbitant price from your local stealership, I probably have an old set off my 2000 that you could have for the price of shipping. They were in perfectly fine condition.
2000 SR5 - Build Thread
Quantumkiwi is offline   Reply With QuoteReply With Quote
bump , coils , rear , rubber , stops
Energy Suspension 8.9104R rear bump stops in place of front bump stops Akkording 5th gen T4Rs 66 01-16-2024 12:10 AM
WTB: Rubber Cone bump stops / North Alabama 68ChargerJMP Want to Buy/Trade 0 09-20-2018 09:08 AM
LTB: 4th Gen Rear Springs & Bump Stops. Tampa, FL SHagood For Sale: Suspension/Wheels/Tires 2 09-11-2018 12:10 PM
Bump stops or overland springs? Or both? ty.goins 5th gen T4Rs 9 05-17-2017 06:40 PM
Hydraulic Bump Stops, or New Coil Springs? foyaboya 3rd gen T4Rs 6 10-13-2010 09:35 AM
