Old 10-22-2020, 07:20 PM #1
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Monroe Quick Strut Front Coils?
The PO of my 4Runner did everything with OEM parts, except for the suspension. He had NTB put on a set of Monroe Quick Struts. When I look up the Part #, it shows the same quick strut for all models of 4Runner, regardless of 2wd/4wd or 15/16" wheels. I know there are like 5 or 6 different front springs from 1996-2002.
Does anyone have specs on the springs that come on the Monroe Quick Struts? I can't find anything on their tech info other than "coil rates correspond to OEM coil rates" - which is of course a lie...
I'm ready to throw the struts in the garbage, but wondering if it's worth it to keep the springs. I plan to get a set of Edelbrock shocks and some AC Delco 99 Tall springs for the rear.
For the front I just don't know what to do. Should I just throw the whole strut out and get new KYB tops mounts too, or just use the Monroe Quickstrut mounts and get new springs and struts? I'm ready to pull the trigger in the next few weeks....Thanks so much!
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 10-22-2020, 07:27 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The monroe quick struts I hate. I would not recommend anyone use those quick struts on the 3rd gen 4runners.
My originals were done so I put those one. Was disappointed from day one. Poor quality in my opinion.
Old 10-22-2020, 07:54 PM #3
stuckinthemud stuckinthemud is offline
stuckinthemud will become famous soon enough
I just installed AC Delco talls front and rear with KYB shocks. Very happy with the ride and the extra height.
If the top hats look good, I would reuse them and replace the shocks and springs.
stuckinthemud is offline   Reply With QuoteReply With Quote
Old 10-22-2020, 08:04 PM #4
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Monroe is pretty crap imo. I’d pitch it all out and start over.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 10-22-2020, 08:09 PM #5
shadow247's Avatar
shadow247's Avatar
Exactly the kind of feedback I'm looking for. Do you mind doing Hub to Fender measurements?
I have a feeling 99 Talls in the front won't actually net me any lift over the Monroe Springs, which is totally fine, but I do want a slight rake, so I may end up adding the 20mm Trim Packers to the rear depending on what the measurements end up at.
The 4Runner Show
Old 10-22-2020, 11:52 PM #6
I'll have to check the measurements tomorrow after work. I never got around to checking the before and after.
I'm guessing I got about 1-1/2" lift front and rear.
Old 10-23-2020, 10:22 AM #7
blaze17's Avatar
blaze17 blaze17 is offline
blaze17 is on a distinguished road
blaze17's Avatar
I installed the Monroe Quick Struts on mine. Mine was kinda low being a 2000 and the quick struts raised it about an inch in the front. I think the springs are fine but the struts don't dampen any better than the old OEM ones.
2000 Limited auto with e-locker
OME 2890 rear springs/Monroe Quick Struts up front
290K
blaze17 is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 12:49 PM #8
I finally got around to measuring hub center to fender. I wish I would have measured the before.
FL = 21.5" FR = 21"
RL = 21.25 RR = 21"
This is with 1/4 tank of fuel and no driver (Me).
front , monroe , quick , springs , struts
sr5 front strut coils CalicoSR5 5th gen T4Rs 7 04-27-2023 01:00 PM
Quick ??? front strut cushion retainer orientation? Evan B 4th Gen T4Rs 1 01-01-2013 08:23 PM
Monroe quick struts + moog rear coils after pics ocman40 3rd gen T4Rs 12 11-08-2012 04:47 PM
OME 881 Coils-3" Lift Front Strut Assy w/KYB Gas-A-Just strut-3rd gen runner STRRAYNGE For Sale: Suspension/Wheels/Tires 7 04-30-2012 09:44 PM
Monroe quick struts and shocks lifted front, back stayed the same vivek 3rd gen T4Rs 18 03-31-2012 11:35 PM
