Old 10-23-2020, 01:50 PM #1
Fiffa's Avatar
Fiffa Fiffa is offline
Fiffa will become famous soon enough Fiffa will become famous soon enough
Fiffa's Avatar
Front End "Clap"?
So, I just started to notice a quick and loud clap when there's a decent amount of flex (going around sharp corners, hitting road dips at low speed, etc.) on the front end. I've been digging around the forums, but didn't see anything that addresses the items that I haven't checked/replaced yet. I have removed the sway bar up front, which gives the Bilstein 6112's much more movement. I've seen some mention of a top-out noise, but nothing in particular to a legit "clap".
Here's what I've already checked:
- LBJ's (new within the last 35k)
- Outer tie rods (brand new Moog as of the other week as part of this troubleshooting)
- Inner tie rods (new within the last 25k)
- Steering rack bushings (new within the last 35k)
- Steering rack (I shook it around when replacing the outer tie rods and it seemed firm)
- TBU (two of the four pad retaining clips are broken, which I am trying to find a spring upgrade option for - this is something I think may be the culprit, despite brakes being applied in most cases where I hear the clap and not hearing anything similar with regular brake application)
- Axles (they don't feel like there's any excessive play, but I'm not sure what else I should be looking for. One was replaced in the last 25k; not sure about the other, but it looks relatively new)
What I still need to check/replace:
- LCA bushings (they look fine, but I suspect they are original equipment)
- UCA (have JBA's in the box, so these will be replaced soon)
Considering this is an ongoing troubleshooting project for me and my relative newness to the offroad side of vehicles, I'm more curious if anyone has had the same kind of noise and what they found it was. Because it sounds like a quick metal-on-metal clap, usually at the max compression point of the event, I'm hedging my bets on the retaining clips for the pads or UCA/LCA bushings, but as I have found out thanks to this forum, anything is possible! lol
Thanks!
Fiffa is offline   Reply With QuoteReply With Quote
Old 10-23-2020, 02:44 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Check for witness marks on the upper control arms closest to the coil springs
Old 10-24-2020, 11:19 AM #3
Fiffa's Avatar
Fiffa's Avatar
As in, where the spring could be hitting the arms or to see if the any of the bolts/nuts came loose around the ball joint or main bolt?
Old 10-24-2020, 01:01 PM #4
Real Name: Patrick
Real Name: Patrick
Where the spring and upper control arm may make contact
Old 10-24-2020, 01:54 PM #5
Quantumkiwi's Avatar
Quantumkiwi Quantumkiwi is offline
Quantumkiwi will become famous soon enough
Yea, I had to clearance parts of my coil bucket, the UBJ casting from my SPC control arms was making contact there before bottoming out. Only took like a 1/2 inch notch out of them.
2000 SR5 - Build Thread
Quantumkiwi is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 10:16 AM #6
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
I had a similar rattle/clunk... it was a broken sway bar link
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 10-29-2020, 09:21 PM #7
Fiffa's Avatar
Fiffa's Avatar
Thanks for the info, guys!
I feel pretty confident that it's the brake pads that are only using one of the retaining clips at the moment. I was in a line the other day and the same clap came when I released the brakes, like the pads on the drivers side were slow to reset because of not having tension on one side. I guess I'll just get some extra clips in case they decide to fail again.
bushings , clap , front , rods , tie
Call Him "Spiderman," Not "Antman." Maybe "Lefty." Kraeken 5th gen T4Rs 69 10-18-2013 08:24 PM
"Baja" or "Prerunner" Front Bumper Options tmcintosh3 4th Gen T4Rs 5 08-17-2011 07:10 PM
WTB: 4th Gen "4Runner," "Limited," and "Toyota" badges James_T Want to Buy/Trade 3 06-25-2011 11:42 AM
Zero point didnt work how to turn off "VSC TRAC" & "VSC OFF" & "ABS" lights sciff5 4th Gen T4Rs 6 09-27-2010 12:10 AM
"fog lights", front "grill?", and sport model questions mkingphoto 3rd gen T4Rs 2 03-31-2007 09:47 AM
