Old 10-24-2020, 09:54 AM #1
Mudeprived Mudeprived is offline
Mudeprived is on a distinguished road
Body mounts: too much weight?
I was undercoating the truck yesterday. I went to lower the hi-jack and noticed the body bouncing a little bit as it went down. There is a bit of up and down movement in the rear body mounts.
I haul 1000 lbs of pellets a few times a year. Truck is assisted with air bags. Would this weight be the cause of my worn body mounts?
Has anyone had worn body mounts? I don't think it is a common issue.
1999 Limited
265/75/16 AT51's
Bilstein 4600
Mudeprived is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 10:35 AM #2
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
The body mount bushings do wear out. I don’t think it’s as uncommon as you think. Plus, your 3rd gen is ~20 years old, and all that weight probably sped up the wearing out.
For the 4th gen, when people install a body lift kit, they often replace the front body mounts because the engine weight wears them out faster than the other body mounts. Some replace all of them when they have the body lifted off the frame. Mine looked ok, so I didn’t replace any of the body mounts.
There are threads on this forum about body lifts that talk about replacing the rubber(?) mounts/bushings.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 10-25-2020, 10:57 AM #3
Thanks for replying. I have been looking for replacement body mounts but seems to be difficult to find. I don't want a complete poly kit that costs $200 nor any junkyard mounts. I went through the dealer parts site but pages of pages of mounts. My phone doesn't bring up the diagrams for some reason.
If anyone knows where to purchase factory mounts please share otherwise I will keep looking.
1999 Limited
265/75/16 AT51's
Bilstein 4600
Old 10-25-2020, 11:52 AM #4
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
I've worn out stock rear mounts on a 99 I had 6 years ago, had about 300K, it was bad enough it would bang hitting big bumps. You can replace just the rear mounts if you want, that's what I did.
My current 99 I have Energy Suspension (urethane) body mounts and a 1 inch body lift.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 10-25-2020, 11:59 AM #5
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
the rear of these trucks have a lot of flex in them. the rear mount also is designed for comfort over heavy sustained use, IMO.
the rear mounts do last a good long time 20 years of service is pretty respectable.
I have replaced 2x 3rd gens now with body mounts. I can share my experience.
replaced all mounts on a 2000 lim with OEM mounts yes this was expensive but you can purchase only the mounts if your hardware is in ok condition.
I would suggest this site, use them all the time. they are great, shipping on smaller items makes it doable.
CAB MOUNTING & BODY MOUNTING | 4RUNNER VZN185L-GKPZKA RZN18#,VZN18# | JT3HN87RXY0283787 | Toyota | Genuine Parts Catalogs | PartSouq Auto Parts Around the World
this site also lists the febest parts and they are much cheaper than OEM toyota, I have used some febest stuff... and yes some of it is junk but I have been running the rear mounts from febest for the last couple of weeks and they seem fine so far.
FEBEST TSBLC95 is the rear mount. @ $18 each
you can get them from 2 @ amazon 24.95 * 2 = $49.90 as long as you can
or from partsouq
5220335250 CUSHION SUB-ASSY, CAB MOUNTING, NO.2 17.88$ * 2 = 35.76$ + 24.46 shipping = $60.22
so either $50 for 2 new febest or $60 for 2 new OEM
Old 10-25-2020, 08:40 PM #6
or from partsouq
Thanks. I will take the hardware off and see if I can get by with just the bushing.
1999 Limited
265/75/16 AT51's
Bilstein 4600
Old 10-25-2020, 09:15 PM #7
beklemmung's Avatar
beklemmung beklemmung is offline
Real Name: Levi
beklemmung is on a distinguished road
beklemmung's Avatar
Real Name: Levi
Am I correct in understanding that there are a total of 16 (8x2) mounts/cushions that are needed if you want to replace them all? Looks like Partsouq doesn't have all of them in stock either, which means it's easily north of $300 to replace all with OEM?
or from partsouq
1997 3.4L 4WD auto SR5, nearly 200k miles, pretty much all stock
beklemmung is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 10:06 AM #8
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
yes some have upper and lower bushings. so 18 sounds correct.
It's not free that is for sure. I had similar sticker shock last year when I did it.
Amazon.com: Customer reviews: Body Mount Bushing Set
for $190 all the way around if your hardware is still in good shape is a good deal.
just be careful different years have different body/frame mounts
96 is unique
97,98 same
99-02 same
these trucks are old so... you will have to mix and match if your hell bent on OEM. with a combo of Partsouq, Amazon, toyota parts deal, McGeorge Toyota in VA and my local place I can usually find it. your lucky you live in a place where pick'n pull have non rusty parts. anything going to pick'n pull here in the salt belt is so rusted now it's almost always worthless.
Old 10-26-2020, 11:54 AM #9
beklemmung's Avatar
Real Name: Levi
beklemmung's Avatar
Real Name: Levi
@sleepydad The ES set is available for $180 from Rockauto, and it looks like there are a total of 20 based on the picture. I double-checked the Partsouq diagram you linked and am still coming up with 18... not sure if it's because the Partsouq diagram isn't specifically for a '97 or if there's something else I'm missing.
I think my hardware is in decent shape (truck has lived its entire life in the Southwest / Southern CA). I think I prefer OEM to poly but still doing research on that.
Body mounts: too much weight?-es-set-jpg
Old 10-26-2020, 12:03 PM #10
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
yes variations in the body mounts for different years. they changed the #2 mount in late 98. it's why it shows 2x mount options.
make sure you get the correct set, I have 2 trucks a 2000 and 1997, that set is for a 1997. ES makes different sets.
I have both OEM and poly so I can tell you what I think the difference is.
OEM is a quiet ride and very nice, exactly what you would expect. no surprise here.
poly is firm but not bad, just firm and you get more feedback. not harsh but you can feel more.
my only complaint with poly is when it gets cold (I live in frozen northland) the poly is really harsh. it's like riding on a board. the rubber mounts are harder in the same cold weather but the poly is noticeably harsher. This is only when the temp gets down below 20' F and that might not be a concern being from a warm climate?
this is the one for 2000+
Body Mount Bushings Kit - Toyota 4Runner - 8.4110
this one for 1997,1998
Body Mount Bushings Kit - Toyota 4Runner - 8.4111
note: check out the install stuff that helped me track down the differences in kits as well.
https://www.energysuspensionparts.co...ons/8.4110.pdf
https://www.energysuspensionparts.co...ons/8.4111.pdf
Old 10-26-2020, 12:30 PM #11
beklemmung's Avatar
Real Name: Levi
beklemmung's Avatar
Real Name: Levi
@sleepydad I really appreciate you taking the time to straighten me out and give your feedback! Even though I'm in a warmer climate (for now, at least), I'd prefer to go with OEM if the cost doesn't get too out of control. I'll price it out and make a decision, but again, really appreciate your time and expertise.
Old 11-28-2020, 05:12 AM #12
beklemmung's Avatar
Real Name: Levi
beklemmung's Avatar
Real Name: Levi
Do you know which parts to order for the #2 mount for a 1997? I can't tell from this diagram. The upper bushing looks very different in the two options but both show the same part no. And for the left option, I can't find the part no for the lower bushing (52204B in the diagram).
Old 11-28-2020, 12:15 PM #13
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
I just did the rear body mounts in my 99 LTD 173,000mi using Sonoran Steel poly mount for the rear, and it made a huge difference, the old bushings where ripped and clunking over bumps, I have been undercoating and loading my truck up with wood pellets aswell, nothing crazy maybe 20-25 bags a few times a year for the shop, but I'm sure the oil undercoating has killed almost every rubber bushing in my truck, doing LCA bushings now. try just doing the rears, if you remove the rear tires you can reach the rear body mount bolts between the frame and body, these can be a bugger, I used a oxy torch to heat the weld on nuts, and slipped an exhaust pipe over the bushing so I wouldn't burn it while I heated them up, no way would they come out without heat, I soaked them for months to no avail.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 02:14 PM #14
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
the 97 uses the non bolted one, from top to bottom
I'm 100% sure about this mount because I had to deal with this one on my last go around.
if you look @ the same diagram for a 2000 you will see the updated parts. I don't know why they show the parts for a different VIN but restrict the parts to your VIN, they just do it that way. it's stupid and confusing.
5221735100 BOLT, BODY MOUNTING
5220335200 CUSHION SUB-ASSY, CAB MOUNTING, NO.2
9044016019 TUBE
5220435110 CUSHION SUB-ASSY, CAB MOUNTING, NO.2 LOWER
9462211000 WASHER
9418401001 NUT(FOR BACKING PLATE TO REAR AXLE HOUSING SETTING)
the only part you can't get is the 9044016019 TUBE
and yes the Toyota mounts are expensive
can be found pretty much anyplace stateside
Tube 90440-16019 | Toyota Parts
Old 11-28-2020, 04:50 PM #15
beklemmung's Avatar
Real Name: Levi
beklemmung's Avatar
Real Name: Levi
Thank you! I'm going out now to try to figure out how much of the hardware I can reuse. I'm lucky that my truck has spent all its time in AZ and CA so hoping I can reuse most if not all of it.
One question about the bolt for the #2 mount: you linked 52217-35100. However, in your link it's -35110. And when I search by my VIN, it tells me it's -35050. Should I just assume it's the last one since that's what my VIN brings up, or is there a specific reason you believe it's -35100?
bit , body , mounts , truck , weight
Regarding the OEM body mounts . . . 1985taylor1925 3rd gen T4Rs 11 12-18-2021 05:37 PM
Polyurethane Body Mounts without Body Lift ChildrenOfBodom 3rd gen T4Rs 18 02-21-2016 08:05 PM
154lb body weight bench presses 410lbs T4R # 5 Off Topic 8 06-25-2015 04:39 PM
Polyurethane replacement body mounts with body lift opinions? ellner357 3rd gen T4Rs 0 02-02-2013 12:42 PM
Body mounts Brutus 3rd gen T4Rs 3 03-21-2010 12:53 AM
