Old 10-24-2020, 07:56 PM #1
HunterG425 HunterG425 is offline
HunterG425 is on a distinguished road
Transmission shifting issue
Hey y’all,
I’m looking to buy another 3rd gen and found a nice one, aside from the fact the owner states the truck will only shift into reverse at high RPMs. He said it was a solenoid issue and it was fixable, but I’m skeptical. Any ideas what could be causing that and how expensive/difficult a fix would be?
Thanks!
Sorry- forgot to add it’s a 2001 SR5, V6, automatic
HunterG425 is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 08:12 PM #2
PatrickStapler PatrickStapler is offline
PatrickStapler is on a distinguished road
Recently went through this. Shift solenoids. Truck is running great. New owner couldn’t be happier.
Trans or Torque Converter???
Kind Regards,
Patrick
PatrickStapler is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 09:54 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I agree with Patrick. New filter. Exchange the fluid and if still shifting funky swap or replace the solenoids.
Auto transmissions are readily available if those things do not correct your issue..
Old 10-25-2020, 09:44 AM #4
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
There is a set of 3 american made shift solenoids on truck auto
Old 10-25-2020, 10:59 AM #5
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Offer to help the guy replace the shift solenoids and tell him if it fixes the issue, you'll pay for the solenoids and you'll give him his asking price. If it doesn't fix the issue, you dodged a huge bullet. Yeah, used transmissions for these rigs are plentiful, but there's no guarantee what condition transmission you'll be getting. Personally, I'd only buy a remanufactured trans from Toyota and those run around $2500. Don't buy somebody else's problem is my advice. If the guy won't go for your deal of helping him swap out the solenoids to confirm that was the issue with the trans, walk away.
Old 10-26-2020, 08:30 AM #6
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
I don't think its the shift solenoids. I don't believe the transmission uses the solenoids for reverse gear, it's purely mechanical through the shifter linkage.
If I had to guess, it probably has a plugged up filter which is starving the pump or there is something plugged up in the valve body. The pan would need to be dropped and the filter replaced (likely it is plugged up). The solenoids could also be tested if the pan was dropped just to make sure they are in spec.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 10:08 AM #7
ambush ambush is offline
ambush will become famous soon enough
My last 4runner, KiTT has 581k on it. When I got it the first I did was drain the fluid and filter (Castrol). I followed Tim's video. The truck shifts like a DREAM!!!
Now if you are still up in the air about the one you are looking at, come take a look at mine the one I have for sale.
Current: 1999 4runner Limited 2wd (Desert Trooper) 170k miles! - WIP!
- s13we brake upgrade
New: 2001 4runner SR5 2wd (Silver Surfer) 213k miles! - WIP (looking for engine)
New: 1999 4runner Limited 2wd (KiTT) 577k miles!!!!!!!! - WIP!
Sold: 2000 4runner Limited 2wd 220k miles (idiot! i know)
ambush is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 07:37 PM #8
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
thegipper is correct that the shift solenoids have nothing to do with reverse, it's mechanical, there is a valve in the VB that controls said based off the position of the of the manual valve.
I don't agree with mtbtim "I'd only buy a remanufactured trans from Toyota and those run around $2500". Don't forget that the transmission and all it's internals are not made by toyota... if u can't rebuild one urself u can easily find one like brillo_76 stated.
clearock is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 07:45 PM #9
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
Yea the used auto are super cheap, Brillo got a perfectly working one for $75, I know this because it’s my old auto trans lol
Maybe if I had a super clean California vehicle like Tim I’d get a reman from Toyota, but for the more budget conscious or those with a dented up old 3rd gen id go for a used one in the $100 to $200 range, these transmissions are pretty reliable normally so I wouldn’t worry too much about buying used especially if it has under 200k
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 10-26-2020, 10:53 PM #10
o.jack92 o.jack92 is offline
o.jack92 is on a distinguished road
I’m not trying to hijack this thread. I’m new to the forum and can’t make my own thread yet. I am having transmission problems as well. The past week or so, when I would take off from a dead stop in 1st, the tranny would kick out of gear and grind. I had to hold it in and let the clutch out gently and it seemed like it would catch something with a slight *kachunk* and then finally commit to going into gear. I’ve also been noticing a noise that sounds like a supercharger that would increase/decrease pitch with RPMs.
On Sunday I was driving down the highway and the “supercharger sound” all of a sudden the noise got louder and louder and then I lost 5th gear. Make it the rest of the way in 4th gear and when I hit the off ramp and downshift I realize I have no other gears. Not even reverse, just 4th.
I replaced my clutch about 3k miles ago. Not sure if that has anything to do with it. I picked up a R150 (no T case) off of a 3.0 yesterday for next to nothing.
*SO* I guess I’m asking... what the hell happened? And how do I fix it?
o.jack92 is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 01:00 PM #11
plcfcng's Avatar
plcfcng plcfcng is online now
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
O jack this thread is talking about Automatic my suggestion is start a new thread with something like Jumping out of gear. Most 4runners are autos you are lucky to have a manual if it is a V6. I would start with pulling fluid and see what kind of metal comes out and put that on the post. common
plcfcng is online now   Reply With QuoteReply With Quote
Old 10-27-2020, 08:34 PM #12
Will do, thanks.
98 5-speed SR5
3” lift on 285’s
Endless upgrade list
Lots to get done!
Old 10-27-2020, 11:03 PM #13
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
I don't see in any way how a solenoid would prevent shifting at low RPM but would shift at higher RPM. Thing is electronic and receives the signal at low RPM anyway, should shift.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 08:58 AM #14
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Solenoid may not be opening or closing all the way. Line pressure is higher in the transmission at higher rpm's. Think of the solenoid codes as more of a performance code rather than a not working at all kind of code.
Old 10-28-2020, 03:25 PM #15
lord rigatoni lord rigatoni is offline
lord rigatoni is on a distinguished road
Does your transmission have enough fluid? typically that “supercharger” noise you’re hearing is caused by low trans fluid. if you only hear it in a specific gear then the gear teeth or synchronizer may be worn out. what you’re describing sounds like your gears and synchronizers are worn out. when you shift your shift fork pushes the synchronizer over the gear to allow it to spin with the output shaft. when these synchronizers wear out, they cannot properly meet up with the gears, which can cause the transmission to “lose” gears. the grinding in 1st is likely caused by 1st gear starting to wear out causing it to not properly align with the 1-2 synchronizer which is why it felt as if the truck was out of gear. im by no means a transmission expert so i would do some research online and call some trans technicians. also i agree with plcfcng, post this issue in a separate thread, you will likely get more information that way.
lord rigatoni is offline   Reply With QuoteReply With Quote
issue , i’m , rpms , skeptical , solenoid
Transmission Shifting Hard - New 4R?? Woz1976-MT 5th gen T4Rs 16 08-26-2016 11:53 PM
99 shifting issue ljshein 3rd gen T4Rs 17 03-07-2016 09:30 PM
Interesting transmission lever shifting issue alia176 4th Gen T4Rs 5 06-25-2015 08:16 PM
Shifting issue ncgyver 3rd gen T4Rs 8 03-19-2012 11:27 AM
1990 4Runner Manual Transmission Shifting Issue ScottGruenewald Problems & Warranty Issues 0 01-26-2012 07:17 PM
