Old 04-11-2021, 12:10 AM #46
Devbot's Avatar
Devbot Devbot is online now
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Originally Posted by nateboor View Post
While under here, I am tempted to delete the e-brake which doesn't work anyways, and the Charcoal Canister since there are no vehicle inspections in Michigan. Something about eliminating unnecessary clutter is very appealing. Would be interested to hear opinions on this.
Unless your charcoal canister is malfunctioning I see zero reason to, it only helps you and does nothing to hurt performance. Messing with EVAP unnecessarily is always a can of worms
Devbot is online now   Reply With QuoteReply With Quote
Old 04-12-2021, 12:46 PM #47
Originally Posted by Skulking View Post
While you are under there, you should fix the parking brake.
Especially since that is what (should) auto adjust the rear shoes.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-12-2021, 09:56 PM #48
nateboor nateboor is offline
nateboor is on a distinguished road
Thanks for the response. I don't necessarily understand what is happening in the mysterious black box - I just needed some assurance from others more knowledgeable on the subject to point me in the right direction. 👍
nateboor is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 10:24 PM #49
I've been making decent progress over the past few weeks. Aside for the passenger Lower Control Arm, I have removed everything from the transfer case back (I will get a picture soon).
The LCA is stuck because the cam alignment tabs are stuck/dry rotted into the bushings. I'll need to hit it with my purse more, or sawzall them out and replace with the 333 fab Alignment Cam Eliminator Plates. Between that and removing the old bushings (might just melt those out lol), those are the only old items left to delete.
I will need to run new brake line to the driver rear wheel. That line was rusted where it meets the rubber hose.
We had to bust out the torch to remove the front coilovers, the threads were too rotted and broke the other end of the bolt lose inside so it just turned with no way of holding it.
Anyway, now it is just a TON of cleaning i.e. laying on my back on gravel while grease, rust, and cleaner soak me. I have wire wheeled/air needled the entire axle, frame, and crossmembers clear of any large rust flakes. Now, I am degreasing everything and scrubbing it all with a scouring pad - things actually are looking really nice and its keeping me motivated.
Here are a few pictures... more will be coming soon - thanks for tuning in.
I posted my donor truck on Marketplace for $1200. Some dude showed up and wanted it to try and body swap a 1995 4runner... good luck...? I'm sure it will end up as a part-out.
IMG_4671
I broke the ABS Sensor trying to remove it. Will probly just secure it back on with the 10mm bolt and send. Also, upon removing the axle shafts and inspecting the e-brake assembly, it's toast. I'm removing them and RTV'ing the opening to keep out debris. The cable will probly just be zip-tied across the top of the frame crossmembers until I think of a different solution.
IMG_4624
The EimKieth Lower Link Mount Reinforcements are welded on and clearly add plenty of beef. My welds were uuuuugly, but I needed the practice - they'll hold just fine.
IMG_4613
Old 05-04-2021, 11:38 PM #50
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Most will recommend just cutting out the alignment cams if you're replacing them anyways. No need to make things harder
Old 05-04-2021, 11:48 PM #51
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
I think I might be a day late and a dollar short; but for my swap, I traced the clutch master mount on the firewall to transfer it over.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 02:13 PM #52
You are, but its good info for other people viewing the thread. Cutting those holes definitely could have gone more smooth. Thanks for the picture.
Old 05-06-2021, 10:55 AM #53
toyotaspeed90 toyotaspeed90 is offline
toyotaspeed90 is on a distinguished road
When I cut mine on my 97 limited it was even worse than what y'all are dealing with.
A previous owner had run wiring for an amp but for some reason drilled an almost 1" hole for it. It was right where i needed the CMC to mount and offset.
Luckily I was able to cut it out but not the way you would think.
I used the gasket to trace best I could and then used a very small drill bit to drill the outline- something like 15 holes around the edge of the hole. Then just got progressively larger drill bit until the holes overlapped.
toyotaspeed90 is offline   Reply With QuoteReply With Quote
Old 03-27-2023, 12:47 PM #54
Drifter2080's Avatar
Drifter2080 Drifter2080 is offline
Drifter2080 is on a distinguished road
Hey did you ever get the reverse lights and cruise control wired up?
2001 4Runner SR5 455k (5mt Swapped)
2017 BMW M2 6MT
2008 BMW M3 E92 6MT
1998 BMW 328ic 5MT
2008 Mercedes-Benz C63 AMG & CLS63 AMG
Drifter2080 is offline   Reply With QuoteReply With Quote
Old 03-28-2023, 08:10 AM #55
Unfortunately, no. It's on the spring tune-up list among other things. I'll have to look up the thread where that is explained again. It has been sitting all winter in my condo parking lot.
I drove her hard last summer at Silver Lake Sand Dunes. It performs incredibly well over the bumps, but obviously can't take woops like a LT truck. Really surprised it held up so well after the shakedown, just needed a good bolt check. Drove it an hour there, 2 days in the dunes, then drove it home.
Old 06-05-2023, 08:18 AM #56
Ah I see, lol mine has been sitting all winter in my condo lot too. Haven't had much time to take it out to trails this year, hopefully later in the summer. Please keep us updated if you do figure out the wiring for those two!
2017 BMW M2 6MT
2008 BMW M3 E92 6MT
1998 BMW 328ic 5MT
5-speed , limited , manual , swap
2001 2002 Manual Swap Tyler James Inc 3rd gen T4Rs 33 02-03-2024 12:35 PM
FS: 5-Speed Manual Swap - 3rd Gen 4Runner - OREGON Chim For Sale: T4R Items 5 12-12-2019 06:36 PM
2001 193k flexplate problem or do 5 speed swap?? Moosenuckle92 3rd gen T4Rs 26 11-18-2018 12:56 PM
2001 manual transmission swap questions Project_toothless 3rd gen T4Rs 25 11-21-2015 11:30 PM
6 speed manual swap? mymalade 4th Gen T4Rs 42 09-12-2014 11:01 PM
