Old 10-30-2020, 11:38 AM #16
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by 96RedRunner View Post
I like this route now after doing it couple times on newest Runner, so so maintainence history. Drain n fill not worth the trouble.
Basically its a oil pump and 2 buckets. works great for all vehicles as you can see what comes out and what goes in. If interested on mine. Search the forum its there. I just got carried away and have a 3/4 to 1 inch pump that i use as I kept burning up the cheap Chinese pumps. ;-)
brillo_76 is online now   Reply With QuoteReply With Quote
Old 10-31-2020, 09:42 AM #17
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Originally Posted by brillo_76 View Post
Basically its a oil pump and 2 buckets....;-)
Many ways to skin a cat, I did the exchange with trans pump after 3 D & F's in 20k mi.
Seeing what comes out with fluid important more so with 200k by PO, filtered the fluid with paint filters.
Old 10-31-2020, 09:50 AM #18
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes it is. And why I use clear houses and graduated buckets. So I know how how much came out and how much went in.
Old 10-31-2020, 10:28 AM #19
HiLife HiLife is offline
Yes. I was filtering my spent fluid with metal coffee meshes. Hard to see what's in the spent fluid when the material sinks to the bottom of the bucket full of trans fluid.
Old 10-31-2020, 10:34 AM #20
Real Name: Mark
Real Name: Mark
So I know how how much came out and how much went in. ...
Was paying attention to this at first, wasn't consistant over 26 qts of fluid for whatever reason. Same in same out would vary on stick had to adjust either way.
Old 10-31-2020, 09:31 PM #21
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Always have to adjust but your close. The transmission fluid will go bright red. When its exchanged out.
Sealed transmissions can be done this way and its even easier because you can pull the high plug and pump fluid in until it starts coming out then make sure it's at the correct height at hot by simply pulling a plug with a container under it..
atf , change , condition , fluid , photo
Can't add service record korborh 5th gen T4Rs 19 11-07-2017 10:54 PM
Record keeping SilverRidgeRunner1 3rd gen T4Rs 28 09-13-2016 09:17 PM
Must be new record 8MPG T4Running 3rd gen T4Rs 35 02-16-2015 10:30 AM
New Record Jerrydog 4th Gen T4Rs 22 04-05-2011 12:48 PM
A 4Runner Record???? CannondaleMan General Discussions 18 09-16-2008 07:41 AM
