Originally Posted by Doc3g
So, the next question is, what are the chances of running some aftermarket fogs off the factory harness?
Well the factory fog fuse is 15A, so you can safely run aftermarket fogs up to that amperage. Past that, you can use the fog light switch/circuit to trigger a relay which can then supply whatever amperage your fogs need.
Given your situation, I don't see the point of spending $200 on factory fogs now if you are going to go with an aftermarket bumper in the future.
I have a set of halo foglights that I first had in a minivan, then transferred to underneath the valence in the 4Runner, and now have on my AOR bumper. Very nice foglights:
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
