10-29-2020, 01:12 AM
What switches normally go in these factory panels
I have 4 open panels on the far left of my dash and I'm curious what OEM switches would go here? I'm pretty sure I've seen the e-locker button in some of y'all's post but I'm not sure about the others. I'm curious about a quick and easy way to add some inexpensive fog lights to my truck (I'm going to be replacing the front bumper eventually, so I don't want to spend a ton on them atm) and I'm pretty sure I have factory wiring already under the truck in those locations, so I was hoping that maybe there is a harness already behind there somewhere and that I could pick up a factory fog switch from a junkyard and then just wire in some not-too-expensive fogs for the time being?
Screenshot by Lightshot
10-29-2020, 07:45 AM
I think I've only seen OEM alarm light and possibly e locker in the top right. Although normally the spot next to steering column also has had e locker I believe.
Either way you can do one of two things for your situation.
1: install independent fog light and switch using one of those spots to mount switch.
2: install fog lights and wire into OEM harness and use stock switch on the left stick of steering column that control head lights. This is the route I went...
Depending on your preference and what you're doing with that bumper situation you can pull OEM fogs from a donor or go after market.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
10-29-2020, 07:57 AM
Real Name: Mark
Real Name: Mark
Some I've seen.
A&B seat heat.
C Trac off 2WD
D Mirror control
Locker - Security buzzer
10-29-2020, 10:15 AM
Here’s what I’ve got here. Looks like my e-locker switch is where your Toyota security buzzer is and so they move it to one of the switches but that red light is the previous owners switch for wires I haven’t found yet haha. Anyways if you’re using the oem fog lights the switch should be on the light stalk on the left side of your steering wheel as someone else stated however you can only use it with headlights on and if you turn your brights on it will turn off. I’m sure there is a way to trick it into being hot all the time I’m just not sure how yet.
11-02-2020, 08:27 PM
Originally Posted by Doc3g
Looks like the right one. I can’t imagine it would be too hard but not sure honestly. You’ll know when you go to pick one out of the junkyard haha
11-02-2020, 10:14 PM
Real Name: Leon
Real Name: Leon
That's the right switch for your '99. Don't get the one for newer models ('00-02), which have white connector housings instead of black.
The '99 is probably pre-wired for the foglights, even if you didn't have them. So the new combo switch should be plug and play (other than running wiring to the actual foglights). If not, you can always add the needed 2 pins for the foglight circuit (I had to do that for my '97).
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
11-03-2020, 01:44 AM
Here is a shot of the wiring that exists under the truck near where the fogs would normally go. Is either of these harnesses for the factory fog lamps?
Also, here is a shot of my fuse box. There is a blade fuse in the fog slot but no relay, so do I just need to pop a relay in there, and if so, does anyone have a part number for that relay?
11-06-2020, 01:48 AM
Quick bump since I fixed the pictures in the last post so that they should be showing up now.
11-06-2020, 02:47 AM
Real Name: Greg
Real Name: Greg
Easy AF to install. Just need a steering wheel puller then just plug and play with everything else.
I have a 99 as well
Greg Gonzalez- Realtor- Keller Williams Realty Southwest
-Direct- (702)302-3646
-Email- [email protected]
-Website- GregSellsVegas.Com
-99 4runner 3.4 5spd SR5 4x4 locking differential, 231 tundra brake upgrade, breather mod.
11-06-2020, 08:16 AM
Real Name: Mark
Real Name: Mark
does anyone have a part number for that relay?....
My 01 uses white connector for Fogs, relay part number 90987-02012
11-06-2020, 09:49 AM
Real Name: Leon
Real Name: Leon
Originally Posted by Grgg1978
Easy AF to install. Just need a steering wheel puller then just plug and play with everything else. lk
Even better, you don't need to pull the steering wheel - just the column covers.
11-06-2020, 01:48 PM
Agreed. You get to the screws on the column cover by turning the steering wheel 90* each way.
The white connector in the front-end pic is for the fogs (the other is for the ambient temp sensor that the SR5's don't have). For a '99, you need the correct control stalk, a fuse and the relay - and the lights themselves, of course. I don't have the relay PN offhand, but I just got a used one off eBay, I think... it is a relay used in many Toyotas.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
11-06-2020, 08:34 PM
So, the next question is, what are the chances of running some aftermarket fogs off the factory harness?
Thoughts?
I'm running some Rigid D2 LED fog lights (DOT beam pattern) off the stock wiring/switch. No problem as long as they are 110W or less total. You will obviously need to wire up a different connector...
Cheap lights will have a bad beam pattern and probably shouldn't be used on the street. Even good quality off road lights are not good for the street (no upper beam cutoff). My offroad lights are on a completely different circuit and aren't used on the street (though they make awesome high beams...).
Also keep in mind the stock wiring only allows the fog lights to be on with the low-beam headlights.
