Old 10-29-2020, 05:56 PM #1
toyotaspeed90 toyotaspeed90 is offline
toyotaspeed90 is on a distinguished road
3.4 Coolant bypass hose foam...?
During my engine re-gasket I came across deteriorated foam around the coolant bypass hose back plate - where the plate fills the void between the block, heads, and lower intake.
I called Toyota and they don't list the gasket/foam separately. The full gasket kit I have didn't come with it either.
Toyota wanted $95 for this bypass hose with the foam and I can't justify that price when the hose itself is fine.
What have others done/used? It's too big a gap for RTV...
toyotaspeed90 is offline   Reply With QuoteReply With Quote
Old 10-30-2020, 10:24 AM #2
Buehler..... Buehler.....
Old 10-30-2020, 11:38 AM #3
Pic of offender...
3.4 Coolant bypass hose foam...?-20201030_081354_compress52-jpg
Old 10-30-2020, 11:46 AM #4
That's just a dust cover/seal... use whatever you feel is appropriate.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 10-30-2020, 11:49 AM #5
Right... just trying to find d what others have used.
Most foams readily available are rated up to 150c, or about 300f. That should be fine, but... I tend to prefer over the top.
Thinking maybe some fiberglass rope meant as a stove door gasket.
Old 10-30-2020, 08:51 PM #6
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I have used this one same stuff I think
1132920010
GASKET, TIMING BELT OR CHAIN COVER, NO.2
total of 2.71$
1132920010 Toyota GASKET, TIMING BELT OR CHAIN COVER, NO.2, Price: 2.71$, Weight: 0.014kg - PartSouq Auto Parts Around the World
the only pain is going to be cleaning everything off, it's just self adhesive and things need to be clean else no sticky.
Old 10-30-2020, 09:25 PM #7
If Toyota had found that I would have absolutely ordered it.
Friend came over with an almost foam like seal for fireplaces and a high temp rtv. It's already curing.
Old 03-02-2021, 10:46 AM #8
LP1999 LP1999 is offline
LP1999 is on a distinguished road
3.4 coolant bypass heatshield/dust cover
Hello all,
New member here yet longtime follower of the site.
Going off of the original post I am replacing my 5vz-fe coolant bypass pipe (16268-62060)and the replacement I received from Toyota "Partznet.com" does not have the heatshield/dustcover the OP was discussing concerning the foam. Has anyone else come across this with a new bypass pipe? Did Toyota deem this piece negligible and have since opted not to put it on or did I get an incomplete assembly?
Thank you in advance for your replies.
LP1999 is offline   Reply With QuoteReply With Quote
bypass , coolant , foam , hose , plate
Foam Cover for PCV Hose Near Throttlebody 024rnrSport 3rd gen T4Rs 4 08-21-2020 05:28 PM
3.0 Foam under Intake and Coolant Pipe HanginInUtah Classic T4Rs 1 10-06-2016 09:17 AM
Sea Foam again...PCV hose or Throttle Body? swampy_swimmer 3rd gen T4Rs 3 07-06-2012 01:08 PM
Sea Foam - Which Hose? Dylan Classic T4Rs 14 09-13-2011 12:58 AM
TB coolant bypass mod t4rv8 4th Gen T4Rs 8 10-18-2010 03:04 AM
