Old 10-29-2020, 10:30 PM #1
mendozer mendozer is offline
mendozer is on a distinguished road
brake drum tips
Did my rear axles and new brakes. One went on fine after adjusting the screw down to 0 with some finesse, the other just won't go on. The bleeder is open, I've squeezed them together, etc, it just won't fit. I need two extra hands for this. any other brake drum tips you can think of?
mendozer is offline   Reply With QuoteReply With Quote
Old 10-30-2020, 12:35 AM #2
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
What screw are you talking about? You should be more specific. A photo would be nice (if you can take one, but not necessary).
________________________________
2000 Toyota 4Runner 4x4 Limited Sport Package V6
Old 10-30-2020, 09:33 AM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
If the adjuster is all the way in and you still aren't able to fit the drum then check the bottom pivot points for the shoes and make sure they are seated correctly. Check the adjuster linkage components as well to verify they are seated on the cutouts on the shoes correctly as well. You might need to disconnect the parking brake cable from the brakes on that side too.
EDIT: If you are reusing your old drums then I would get them turned to get rid of any lip that may be interfering with getting them on.
Old 10-30-2020, 11:59 AM #4
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Good visual reference to make sure you have everything in place correctly.
Drum Brake Shoe Replacement - YouTube
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 10-30-2020, 12:11 PM #5
bullwhipit bullwhipit is offline
bullwhipit is on a distinguished road
Hey there I just did my 4runner recently and what I do is place a small board or me on the other hand a small piece of cut PVC on the pistons and place a locking caliper and squeeze it together for about three min. and presto. Double check to make sure you have the pads in correctly because it is easy to get it backwards. I had to lightly hammer one in one time with a rubber mallet.
Good Luck
bullwhipit is offline   Reply With QuoteReply With Quote
Old 10-30-2020, 12:32 PM #6
here's a pic. I was referring to the adjustment screw. Bottomed out at 0, teh drum still barely won't fit on. And nothings kinked or not lined up straight from what i can tell
brake drum tips-pxl_20201030_162756624-jpg
Old 10-30-2020, 12:49 PM #7
As for the orientation, I did one at a time so I wouldn't mix it up. So the parking brake levers are on the side closer to the front of the vehicle. I don't seem to have the same style of screw adjusting plate that Timmy does, or even the manual I have. I didn't change anything that's just the hardware I have.
All new springs, pins, etc of course
Old 10-30-2020, 01:32 PM #8
turbodudey2's Avatar
turbodudey2 turbodudey2 is offline
turbodudey2 will become famous soon enough
There are quite a few things wrong with this assembly.
1) The adjuster is not seated into the notch in the brake shoe (this is why the drum won't go on)
2) The return spring is not located in the correct holes (see picture below). I can't tell if the left end of the spring is hooked in the correct place. The right end is definitely not.
I can't see the bottom of the shoes or the bottom springs to tell if those are correct or not.
'96 Toyota 4Runner Limited 4x4, Supercharged
turbodudey2 is offline   Reply With QuoteReply With Quote
Old 10-30-2020, 01:51 PM #9
I also don't recognize that blue spring on the right hand side.
Old 10-30-2020, 02:27 PM #10
you're absolutely right. not sure how I overlooked the spring. The screw thingy was in there, just looks off in the picture. all snugged up now.
The anchor spring (bottom one) i had hooks facing out vs in like Tim's video, but there are no moving parts down there, I didn't see the need to flip those.
Old 10-30-2020, 02:29 PM #11
that's for the lever that touches the auto adjust screw wheel. IDK why but my setup looks different that Tim's video where there's the plate on top of the parking brake adjustment lever. On mine I had this plat that mounts to the back of the opposite shoe with a spring. This was exactly how it was on the setup upon removal
Old 10-30-2020, 05:12 PM #12
Real Name: Patrick
Real Name: Patrick
All 3rd gen 4Runner's have the same rear drum brake setup except for different size wheel cylinders.
It should look like the attached photo. That photo is of the passenger side so it will be reversed for the driver side.
EDIT: 2001-2002 are different. I stand corrected and will leave my original foolishness intact for others to learn from. Thanks for the knowledge mendozer
File Type: pdf BR-31 Installation (2000 4Runner) Rear Drum Brake.pdf (75.3 KB, 50 views)
Old 10-30-2020, 05:38 PM #13
My FSM has the same pictures, but that's now how it hooked up on my end. Tim's video even says in the caption that the 01-02 are set up a little differently. Unfortunately I have no other way to verify the setup other than how mine looked coming off the old brakes.
Also my auto adjustor looks a little different, it sits over a pin on the shoe opposite of the brake lever and comes up from behind the adjustment wheel.
Old 10-30-2020, 05:44 PM #14
http://www.toyota-4runner.org/2030784-post10849.html
here ya go, a better picture showing how it's different. see, I'm not crazy (this time)
Old 10-30-2020, 05:48 PM #15
Real Name: Patrick
Real Name: Patrick
Toyota 4Runner Forum - Largest 4Runner Forum - View Single Post - What Did You Do To Your 3rd Gen Today?
I stand corrected! You learn something new every day. Thanks for the link and info
brake , drum , fit , squeezed , tips
Parking Brake transfer cable inside brake drum JBDaddy 3rd gen T4Rs 8 03-14-2017 03:09 PM
Drum Brake Help rcrick 3rd gen T4Rs 42 01-03-2015 01:05 PM
Need some drum brake help!!! Army97 3rd gen T4Rs 25 05-09-2012 10:24 PM
Drum brake 4Running Daily 3rd gen T4Rs 8 02-05-2012 11:34 PM
85 Brake drum nofe3o2 Classic T4Rs 12 08-31-2010 10:55 PM
