Old 11-02-2020, 06:12 PM #1
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
quick advice on engine and switching engines
sorry.
dont know how to delete a thread.
have to pass on my idea
Old 11-02-2020, 06:27 PM #2
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Sorry to hear about the loss of your rig. I don't think that swap has many differences except injectors(which work with both ECU's), and I'm not sure if there is a difference in a few electrical plugs, but you have the engine wiring harness and everything to change whatever comes up so your good, might wanna do the rear main and oil pan since its out and inspect the flex plate throughly, since it's rare to have access to these components. I think you have to do the oil pan to pull the rear main seal housing if I remember correctly from the last time I did that years ago. And you'll need at the very least 4' of 1/2" extensions to reach the trans to engine bolts, don't loose the engine to trans alignment pins in the process sometimes they stick to the tranny sometimes to the engine and get forgotten/lost.
Well, regarding the other shops diagnosis,.. It doesn't have lifters, so I dunno what more to say about that, except I wouldn't be asking them for more engine related advice.
I'd pick the quietest, cleanest, lowest mileage and best compression motor you can find, I know the JDM stuff is a crap shot now, use to be the go to in the early 2000's, now you just don't know till you open it up and then they void the warranty because you opened it, can get sketchy quick.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 11-02-2020, 06:34 PM #3
Real Name: 3 Bears
Real Name: 3 Bears
thanks gonna pass...dont have a place to park two for the winter.....alaska
gonna delete the question
day , engine , knock , parts , quick
Push button start: Restarting the engine without switching off the radio? TheNormsk 5th gen T4Rs 8 08-02-2019 10:59 AM
Question about switching to Mobil 1 synthetic engine oil BIG 4th Gen T4Rs 33 08-16-2014 12:49 PM
Want to buy 190hp 3VZE... Oregon Engine Rebuilders or Raptor Engines? 2ndGen4runner4x4 Classic T4Rs 26 04-12-2013 12:08 AM
Need Some Quick Advice Please!! bosmob Classic T4Rs 3 07-06-2010 07:14 PM
Switching from mineral to synthetic engine oil. Flush? paraordnance 4th Gen T4Rs 4 05-22-2009 11:55 PM
