11-11-2020, 08:39 AM
#16
I found this for 20 dollars. Need to measure my back spacing. It’s for a Denso
11-11-2020, 08:41 AM
#17
And this from metroautoinc
11-11-2020, 02:32 PM
#18
I ordered 24-82264 it’s the 14mm belt 15mm shaft diameter.
Three places has this OD different ranging from 48mm-49.5mm-50mm. We will see what happens.
I think the Alt portion of the harmonic balancer is 157mm. If that’s the case these are the rpm increases from the stock 53mm to 48mm
157mm x 53mm = 1777rpm of Alt at 600rpm.
157mm x 50mm = 1884rpm of Alt at 600rpm
157mm x 48mm = 1962rpm of Alt at 600rpm
11-29-2020, 04:54 PM
#19
It looks the 50mm pulley increased the output by 2-4amps.
The shaft size of the 80a is bigger than the 70a. So I couldn’t swap the pulley onto the 80a to see if there is a difference.
I think a 48mm pulley would do the job. If I turn off the fogs the voltage holds steady at 13.23-13.28v with the 50mm pulley in the 70a Alt.
11-29-2020, 06:03 PM
#20
I'm sure the difference would be the same outcome as it is rpm based, I guess you could've tried the slightly larger 53mm pulley so it did'nt quite charge as much, Nothing wrong with charging at idle though, especially for my plow truck.
You mentioned a few numbers
157mm x 53mm, I think it's 15.7mm ID X 53mm OD x 14mm 4 rib belt width, it would make sense it would be 15.7mm ID to fit a 15mm alt shaft.
Do you no what the cold weather 80 amp Alt shaft size is off hand if someone tries to repeat what you have done. I think all the Canadian 4R's have the larger alt, I know my 99 has a 120amp Alt fuse under the hood.
11-29-2020, 06:45 PM
#21
I’m pretty sure it’s 17mm. I’m looking for a 17mm ID 48mm OD for my 80a.
All I have to do is just touch the gas and the voltage goes back to 14v.
11-29-2020, 07:07 PM
#22
I forgot you mentioned OEM is 53mm, sounds like the 50mm OD put you in the perfect spot especially if you run fogs and markers and a few other items. I think the 48mm OD would make it charge even more than you'd need/want.
Sounds like I might be looking for:
17.7mm ID x 50mm OD, x 14mm 4 rib
Thank you for the info!
12-01-2020, 09:35 PM
#23
Originally Posted by 19963.4lsr5
Well I removed the pulley from my 70a Alt and got disappointed.
Shaft size is 15mm and I measured the pulley OD as 53mm. Plus it looks exactly like the picture I posted.
When I said the factory pulley is 55mm I was going by the specs on a website for a replacement Alt.
So I think my hopes are dashed. I haven’t found a 50mm pulley with a 15mm shaft size.
Hey by any chance do you still have this old original pulley? If so could you please take a measurement of this diameter? I’m trying to machine an add on to drive my York compressor.
12-01-2020, 10:32 PM
#24
Factory pulley on the 70a Alt is 15ID and 53OD I do not have the belt offset measurement.
12-02-2020, 12:41 AM
#25
Do you know the diameter of the inset portion? I want my second pully backing to fit into that inset.
12-02-2020, 12:57 AM
#26
Location: Stationed in Camp LeJeune, home is Conover, NC
Alternator Pulley Shaft Size
If you do this; let me know where you got the pulley from.
I have a York sitting in storage, and want to do the same thing.
I run CO2; but if I can add the York on there; that would be fantastic.
*edit to add:
Assuming this is going on a 3.4.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
12-02-2020, 01:12 AM
#27
*edit to add:
Yup its going on the 3.4. I might have to machine my own pulley if I cant find one to properly fit. Ill let you know how it goes.
12-02-2020, 05:10 AM
#28
I’ll get you your answer today.
12-02-2020, 07:41 AM
#29
43mm
12-04-2020, 06:09 PM
#30
Here is the pulley I bought it’s 50mm OD and 15mm ID.
