Old 11-11-2020, 08:39 AM #16
I found this for 20 dollars. Need to measure my back spacing. It’s for a Denso
Old 11-11-2020, 08:41 AM #17
And this from metroautoinc
Old 11-11-2020, 02:32 PM #18
I ordered 24-82264 it’s the 14mm belt 15mm shaft diameter.
Three places has this OD different ranging from 48mm-49.5mm-50mm. We will see what happens.
I think the Alt portion of the harmonic balancer is 157mm. If that’s the case these are the rpm increases from the stock 53mm to 48mm
157mm x 53mm = 1777rpm of Alt at 600rpm.
157mm x 50mm = 1884rpm of Alt at 600rpm
157mm x 48mm = 1962rpm of Alt at 600rpm
Old 11-29-2020, 04:54 PM #19
It looks the 50mm pulley increased the output by 2-4amps.
The shaft size of the 80a is bigger than the 70a. So I couldn’t swap the pulley onto the 80a to see if there is a difference.
I think a 48mm pulley would do the job. If I turn off the fogs the voltage holds steady at 13.23-13.28v with the 50mm pulley in the 70a Alt.
Old 11-29-2020, 06:03 PM #20
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
I'm sure the difference would be the same outcome as it is rpm based, I guess you could've tried the slightly larger 53mm pulley so it did'nt quite charge as much, Nothing wrong with charging at idle though, especially for my plow truck.
You mentioned a few numbers
157mm x 53mm, I think it's 15.7mm ID X 53mm OD x 14mm 4 rib belt width, it would make sense it would be 15.7mm ID to fit a 15mm alt shaft.
Do you no what the cold weather 80 amp Alt shaft size is off hand if someone tries to repeat what you have done. I think all the Canadian 4R's have the larger alt, I know my 99 has a 120amp Alt fuse under the hood.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 11-29-2020, 06:45 PM #21
I’m pretty sure it’s 17mm. I’m looking for a 17mm ID 48mm OD for my 80a.
All I have to do is just touch the gas and the voltage goes back to 14v.
Old 11-29-2020, 07:07 PM #22
Malcolm99's Avatar
Malcolm99's Avatar
I forgot you mentioned OEM is 53mm, sounds like the 50mm OD put you in the perfect spot especially if you run fogs and markers and a few other items. I think the 48mm OD would make it charge even more than you'd need/want.
Sounds like I might be looking for:
17.7mm ID x 50mm OD, x 14mm 4 rib
Thank you for the info!
Old 12-01-2020, 09:35 PM #23
ArmArak's Avatar
ArmArak ArmArak is offline
ArmArak will become famous soon enough ArmArak will become famous soon enough
ArmArak's Avatar
Originally Posted by 19963.4lsr5 View Post
Well I removed the pulley from my 70a Alt and got disappointed.
Shaft size is 15mm and I measured the pulley OD as 53mm. Plus it looks exactly like the picture I posted.
When I said the factory pulley is 55mm I was going by the specs on a website for a replacement Alt.
So I think my hopes are dashed. I haven’t found a 50mm pulley with a 15mm shaft size.
Hey by any chance do you still have this old original pulley? If so could you please take a measurement of this diameter? I’m trying to machine an add on to drive my York compressor.
ArmArak is offline   Reply With QuoteReply With Quote
Old 12-01-2020, 10:32 PM #24
Factory pulley on the 70a Alt is 15ID and 53OD I do not have the belt offset measurement.
Old 12-02-2020, 12:41 AM #25
ArmArak's Avatar
ArmArak's Avatar
Do you know the diameter of the inset portion? I want my second pully backing to fit into that inset.
Old 12-02-2020, 12:57 AM #26
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
Alternator Pulley Shaft Size
If you do this; let me know where you got the pulley from.
I have a York sitting in storage, and want to do the same thing.
I run CO2; but if I can add the York on there; that would be fantastic.
*edit to add:
Assuming this is going on a 3.4.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 12-02-2020, 01:12 AM #27
ArmArak's Avatar
ArmArak's Avatar
*edit to add:
Yup its going on the 3.4. I might have to machine my own pulley if I cant find one to properly fit. Ill let you know how it goes.
Old 12-02-2020, 05:10 AM #28
I’ll get you your answer today.
Old 12-02-2020, 07:41 AM #29
43mm
Old 12-04-2020, 06:09 PM #30
Here is the pulley I bought it’s 50mm OD and 15mm ID.
alt , alternator , idling , pulley , shaft
OEM Denso alternator pulley nut size? Brandt 3rd gen T4Rs 3 01-10-2021 09:00 PM
Alternator pulley confusion Joelzy 3rd gen T4Rs 8 08-30-2020 01:27 PM
Alternator Pulley “Moan” ccurry0016 3rd gen T4Rs 16 04-09-2020 12:03 AM
Crank shaft pulley bolt - HELP!!! knothead 3rd gen T4Rs 14 04-05-2014 10:25 PM
Removing alternator pulley NCrunner0 3rd gen T4Rs 8 11-11-2012 12:10 AM
