Old 11-04-2020, 07:30 AM #1
Alternator Pulley Shaft Size
Does someone have a spare Alt that they can tell me the shaft diameter?
I want to try and find a different pulley to speed up the Alt at idle.
The factory Alts (both the 70a and the 80a) are only capable of pushing 40a idling in gear at 600rpm. At 750rpm idling in park or neutral they produce enough to maintain system voltage with everything on.
Old 11-04-2020, 09:57 AM #2
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
Just do the CS144 upgrade.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 11-04-2020, 10:22 AM #3
Yea I know, but if I can put a 15 dollar pulley on and speed up the Alt a tad I’m all for it. I think a 57mm pulley will spreed it up enough.
Edit: I need to go down 2mm to speed up the Alt. I doubt I’ll find something smaller than 55mm
Old 11-04-2020, 03:27 PM #4
This is what I was thinking.
It will increase rpm around 70-80. Its 15 dollars but I need to verify shaft size.
Old 11-05-2020, 12:17 AM #5
Doc2012's Avatar
Doc2012's Avatar
I mean, you can.
But the CS144 is pretty much plug and play; and puts out 80-110 amps at idle (speed depending); which is what the stock alternator maxes out at.
I’d just do the CS144.
Old 11-05-2020, 06:53 AM #6
I’ve got all the info to do the CS144 and have had one picked out on DB Electricial for a few years now.
Just never pulled the trigger yet.......
Old 11-05-2020, 11:13 AM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
$15 to $20 to try isn't bad at all. That just my be enough to get the rpms your after.
I don't have any Alts out at the moment or I get you that measurement of the shaft for you. :-)
Old 11-05-2020, 12:17 PM #8
I have a spare Alt at my house that my Ex is supposed to be out of by the 20th. Tomorrow I’m stopping out to do yard work and pick up the dogs for my 5 day off stretch. I should be able to get the info.
Old 11-05-2020, 12:24 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Ok... If you cant let me know. I pull one off and check it for you.
Old 11-05-2020, 02:54 PM #10
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
I've often thought this would be a great idea, I have a hydraulic plow on my 97 which serves to plow only the drive way now, dual batteries isolated via a switch, without driving it on the Hwy and the short trips plowing I have trouble keeping batteries in it at -30*, looked at the high output alts, but I'm convinced charging at idle would be better/economical, and a smaller pulley would be the simple answer if you can get that nut off, perhaps a chain visegrip wrench and impact would do it, but you'll trash the factory pulley-no biggy I guess since it's being swapped. It really doesn't start charging until 1500RPMS if I recall correctly.
**That pulley pictured looks to have to many grooves though like a serpentine belt as per description although often confused, ours are only 4 groove belts.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 11-06-2020, 06:55 PM #11
Well I removed the pulley from my 70a Alt and got disappointed.
Shaft size is 15mm and I measured the pulley OD as 53mm. Plus it looks exactly like the picture I posted.
When I said the factory pulley is 55mm I was going by the specs on a website for a replacement Alt.
So I think my hopes are dashed. I haven’t found a 50mm pulley with a 15mm shaft size.
Old 11-06-2020, 07:22 PM #12
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Oh bummer. I was liking this idea.
Old 11-06-2020, 07:55 PM #13
I’m bummed. Shy of making one on the lathe at work..........
Old 11-07-2020, 01:55 PM #14
RotaryDreamz's Avatar
RotaryDreamz RotaryDreamz is offline
Real Name: Sean
RotaryDreamz will become famous soon enough
Real Name: Sean
Do it! I'll buy your prototype. Surprised they dont have pulleys in all shapes and sizes.
RotaryDreamz is offline   Reply With QuoteReply With Quote
Old 11-08-2020, 11:27 AM #15
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Wouldnt be a bad idea to build one to see if your theory is correct?
alt , alternator , idling , pulley , shaft
OEM Denso alternator pulley nut size? Brandt 3rd gen T4Rs 3 01-10-2021 09:00 PM
Alternator pulley confusion Joelzy 3rd gen T4Rs 8 08-30-2020 01:27 PM
Alternator Pulley “Moan” ccurry0016 3rd gen T4Rs 16 04-09-2020 12:03 AM
Crank shaft pulley bolt - HELP!!! knothead 3rd gen T4Rs 14 04-05-2014 10:25 PM
Removing alternator pulley NCrunner0 3rd gen T4Rs 8 11-11-2012 12:10 AM
