11-05-2020, 07:46 PM
what skid cover is this?
Putting things back from a long overhaul and I don't recognize this panel LOL. I removed the basic skid plate and fuel filter covering. I don't recognize this.
FYI I worked under the engine, fuel filter, rear diff, driveshaft.
11-05-2020, 08:00 PM
In the front wheel well I think. Drivers side on a 3rz but that looks shaped for the passenger side. Maybe 5vz is different.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
11-05-2020, 08:38 PM
Real Name: Ty
Real Name: Ty
Yeah I believe that goes in the passenger side wheel well.
2002 4Runner Sport -->Build Thread <--
2017 4Runner TRD ORP
2002 Toyota 4Runner - Sold
11-06-2020, 07:46 AM
it's the seal between the body and the chassis, LH side beside the shock tower
11-06-2020, 08:30 AM
Real Name: Mark
Real Name: Mark
Felt goes to engine side so that's RH side rearward of strut tower. My 5VZ is on LH side.
Wouldn't mind having one for R side, Thanks for posting, didn't know such a thing available..
Edit: Second pic has road grime & undercoating = wheel side. Wonder what got this put on RS ?
My 01 LTD on DS, 96Red LTD had soft rubber 4 sides. Both 5VZ.
11-06-2020, 01:52 PM
I thought I had a picture of it on my 4Runner... turns out it was removed in the pic... it goes in the open space behind the shock tower:
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
11-06-2020, 02:29 PM
awesome thanks everyone for the answers. I'll get that on today!. I must have removed it to get to the engine block coolant plug
11-06-2020, 10:29 PM
seems like the the foam seal was left and has attached to the ladder frame
11-06-2020, 11:02 PM
Real Name: Mark
Real Name: Mark
Foam is taped to frame rail on purpose no idea what purpose is.
11-06-2020, 11:22 PM
i thought it was taped to the fender apron plastic cover because when i removed mine, it came with the plastic cover
11-06-2020, 11:45 PM
Real Name: Mark
Real Name: Mark
Lol, who knows where it should be taped, maybe yours built on Friday or Monday or mine, 2 so far taped to frame mine n phattyduck's.
11-06-2020, 11:55 PM
Real Name: Mark
Real Name: Mark
My local Ace carries the fasteners yours probably.
Coolant plug sounds right or starter.
11-07-2020, 05:54 PM
ok at the risk of being an idiot...it still wouldn't go anywhere. I checked my driver side to compare but nothings there. On my passenger side I have two of the soft flaps with those pull out buttons. One in front of the shock tower and one behind. And I looked at the triangular piece and couldn't make it line up with anything.
11-07-2020, 06:33 PM
Are you sure it doesn’t go in the drivers wheel well exactly where Charlie said? It sure looks like that part to me.
If you look at Charlie’s photo, it goes behind the spring, not above it. That coil of brake line should not be visible once the cover is in place.
Edit: I’m positive it fits in there, fuzzy side in. Oddly my 96 does not have the fuzzy fabric.
-2001 Echo D.D.
11-08-2020, 12:56 PM
Real Name: Leon
Real Name: Leon
It goes on the driver side, behind the wheel, exactly where Charlie showed. Felt side towards the engine. Just like this (I have an all rubber shield installed in its place because of the body lift):
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
