Old 11-05-2020, 07:46 PM #1
mendozer mendozer is offline
mendozer is on a distinguished road
what skid cover is this?
Putting things back from a long overhaul and I don't recognize this panel LOL. I removed the basic skid plate and fuel filter covering. I don't recognize this.
FYI I worked under the engine, fuel filter, rear diff, driveshaft.
what skid cover is this?-pxl_20201105_195159893-jpg  what skid cover is this?-pxl_20201105_195207642-jpg
mendozer is offline   Reply With QuoteReply With Quote
Old 11-05-2020, 08:00 PM #2
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is a jewel in the rough Kanoe is a jewel in the rough Kanoe is a jewel in the rough Kanoe is a jewel in the rough
Kanoe's Avatar
In the front wheel well I think. Drivers side on a 3rz but that looks shaped for the passenger side. Maybe 5vz is different.
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 11-05-2020, 08:38 PM #3
Niteghost Niteghost is offline
Real Name: Ty
Niteghost is on a distinguished road
Real Name: Ty
Yeah I believe that goes in the passenger side wheel well.
2002 4Runner Sport -->Build Thread <--
2017 4Runner TRD ORP
2002 Toyota 4Runner - Sold
Niteghost is offline   Reply With QuoteReply With Quote
Old 11-06-2020, 07:46 AM #4
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G is on a distinguished road
it's the seal between the body and the chassis, LH side beside the shock tower
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 11-06-2020, 08:30 AM #5
96RedRunner is a jewel in the rough 96RedRunner is a jewel in the rough 96RedRunner is a jewel in the rough
Felt goes to engine side so that's RH side rearward of strut tower. My 5VZ is on LH side.
Wouldn't mind having one for R side, Thanks for posting, didn't know such a thing available..
Edit: Second pic has road grime & undercoating = wheel side. Wonder what got this put on RS ?
My 01 LTD on DS, 96Red LTD had soft rubber 4 sides. Both 5VZ.
Old 11-06-2020, 01:52 PM #6
phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold
I thought I had a picture of it on my 4Runner... turns out it was removed in the pic... it goes in the open space behind the shock tower:
'16 Honda Odyssey
Old 11-06-2020, 02:29 PM #7
awesome thanks everyone for the answers. I'll get that on today!. I must have removed it to get to the engine block coolant plug
Old 11-06-2020, 10:29 PM #8
seems like the the foam seal was left and has attached to the ladder frame
Old 11-06-2020, 11:02 PM #9
Foam is taped to frame rail on purpose no idea what purpose is.
Old 11-06-2020, 11:22 PM #10
i thought it was taped to the fender apron plastic cover because when i removed mine, it came with the plastic cover
Old 11-06-2020, 11:45 PM #11
Lol, who knows where it should be taped, maybe yours built on Friday or Monday or mine, 2 so far taped to frame mine n phattyduck's.
Old 11-06-2020, 11:55 PM #12
My local Ace carries the fasteners yours probably.
Coolant plug sounds right or starter.
Old 11-07-2020, 05:54 PM #13
ok at the risk of being an idiot...it still wouldn't go anywhere. I checked my driver side to compare but nothings there. On my passenger side I have two of the soft flaps with those pull out buttons. One in front of the shock tower and one behind. And I looked at the triangular piece and couldn't make it line up with anything.
what skid cover is this?-pxl_20201107_203057557-jpg  what skid cover is this?-pxl_20201107_203101508-jpg
Old 11-07-2020, 06:33 PM #14
Kanoe's Avatar
Kanoe's Avatar
Are you sure it doesn’t go in the drivers wheel well exactly where Charlie said? It sure looks like that part to me.
If you look at Charlie’s photo, it goes behind the spring, not above it. That coil of brake line should not be visible once the cover is in place.
Edit: I’m positive it fits in there, fuzzy side in. Oddly my 96 does not have the fuzzy fabric.
-2001 Echo D.D.
Old 11-08-2020, 12:56 PM #15
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a glorious beacon of light 4Runner4Leon is a glorious beacon of light 4Runner4Leon is a glorious beacon of light 4Runner4Leon is a glorious beacon of light 4Runner4Leon is a glorious beacon of light 4Runner4Leon is a glorious beacon of light
Real Name: Leon
It goes on the driver side, behind the wheel, exactly where Charlie showed. Felt side towards the engine. Just like this (I have an all rubber shield installed in its place because of the body lift):
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
filter , fuel , plate , recognize , skid
WTB 3rd gen tow hook cover front bumper/skid plate 004wd Want to Buy/Trade 2 05-01-2014 02:17 PM
skid plates and cargo cover for sale. Tearsfallred4u For Sale: T4R Items 4 03-27-2012 12:24 AM
WTB: front skid plate/cover and oil pan cover for 3rd gen. gilp Want to Buy/Trade 0 02-24-2011 12:23 AM
Oil Pan Skid Plate Cover dbogey Maintenance/Detailing 4 10-22-2006 05:34 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
