Real Name: Jeff
Real Name: Jeff
Removing high pressure line from pwr steer reservoir need immediate help pls!
17mm on end of banjo fitting but whole unit from reservoir is spinning out.
Appears to 24mm on whatever that fitting is going into reservoir, I don’t want to assume and screw anything up, was supposed to be at hydraulic shop an hr ago...
Do I simply lock onto the fitting going into reservoir and hold while removing 17mm banjo bolt, that right?
Thx in advance,
jeff
