Old 11-10-2020, 01:17 PM #1
jhuerta22's Avatar
jhuerta22 jhuerta22 is offline
jhuerta22 is on a distinguished road
jhuerta22's Avatar
Intermittent Grinding on Pavement.
So this fall, I noticed a grinding sound coming from the front end of my 4runner when I'm at highway speeds. It sounds like metal on metal so I am pretty concerned about what it could be. The problem is, it's intermittent and comes and goes as I drive it. I've tried replicating it with turns, upshifting, downshifting, braking, and about anything else I could think of.
Earlier this month I jacked up the front end, checked the ball joints, CV axles, tie rod ends, U-joints, and brake rotors. Everything felt tight with little to no play. I rotated the tires and that seemed to help for a while, but now I noticed it's back off and on, but not as frequently as it was.
Any ideas on what it could be? Loose brake pad leaning against the rotor maybe? I swapped the factory rotors for the Tundras a couple of years ago.
Huerta
"Black Burro" 2000 4Runner SR5, e-locker, Tundra/906 lift, Tundra brakes, 348K
"Fez Johnson (FJ)" 1997 Land Cruiser 40th Anniversary, Antique Sage, triple locked, 195K SOLD
"4-Lo Silver" 2010 4Runner Trail, bone stock, 178K, Lovin' it
jhuerta22 is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 01:31 PM #2
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
Just thinking logically, and this probably isnt it: But are your skid plates fastened nice and tight? They could rattle at highway speeds, perhaps mimicking a metal:metal grind?
Otherwise, when you jack the front end up and spin the tires, do you hear anything? Just trying to rule out the front wheel bearings.
Lastly, it could be the needle bearings in the driver side front axle housing. Climb under the truck and try to wiggle the driver's CV with force. If it has gross movement, this could be it. But, usually this is a roaring noise, not so much a grind, so not sure!
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 11-10-2020, 02:05 PM #3
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Since you did the TBU, is the dust shield bent or scraping on something it shouldn't be?
326WHP 347TQ
Old 11-10-2020, 02:57 PM #4
jhuerta22's Avatar
jhuerta22's Avatar
Originally Posted by WeakSauz View Post
1. But are your skid plates fastened nice and tight?
2. Otherwise, when you jack the front end up and spin the tires, do you hear anything?
3. Lastly, it could be the needle bearings in the driver side front axle housing. Climb under the truck and try to wiggle the driver's CV with force.
1. Yes, they are nice and snug. I don't get much rattle from them.
2. I didn't hear any grinding/metal-on-metal when I spun the tires.
3. "roaring" may be a better way to describe the sound. Kinda like when you hit a milled surface. Hoping and praying it wouldn't be the bearings in the spindles. Is that what you are referring to or in the front diff housing? There is some play in the CV's when I pull on them, but not any more than I noticed when I installed them new 4 years ago. They don't click when I'm at full turn, so I think those are okay.
EDIT: If it were the bearings, would the sound be more constant? It happens infrequently and more so when I've been driving 10-15 minutes. Possibly the heat from spinning causing the bearings to catch?
Huerta
Old 11-10-2020, 02:59 PM #5
jhuerta22's Avatar
jhuerta22's Avatar
I checked those and there is clearance between the shields and rotors. If I recall, isn't there a retaining spring on the calipers that holds the pins/pads in place?
Huerta
Old 11-10-2020, 03:11 PM #6
Referring to the needle bearings in the front axle housing:
ECGS Clamshell CV Axle Bushing Install - YouTube
Start at the 8minute mark
Old 11-10-2020, 06:22 PM #7
Real Name: Jerod
Real Name: Jerod
There's an "M" shaped clip that keeps tension on the brake pads so they don't move around. I ended up using two per side as one didn't keep the pads in place.
326WHP 347TQ
Old 11-10-2020, 06:51 PM #8
jhuerta22's Avatar
jhuerta22's Avatar
Thanks, Sauz. Yeah, on both sides the wiggle of the CV is pretty bad. I was just tugging on them in and out to see if one wasn't seated in completely. Spot on with your assessment!
Watching the video makes the replacement look like a job for a more experienced individual than myself. Do you have any experience replacing these? It might cost more in parts and tools than hiring it out.
Huerta
Old 11-11-2020, 09:43 AM #9
If the vehicle you're wiggling the CVs on is the 331k mile one in your sig, this is likely something to address. However, it is a pretty involved job and you'd do yourself a service to verify that this is the actual problem with someone local who knows Toyotas. I would hate for you to tear into it and this isnt even the issue. My gut tells me it is
I've never done it myself, but had a diff built with the needle bearing eliminator already installed
Old 01-13-2021, 07:02 PM #10
jhuerta22's Avatar
jhuerta22's Avatar
UPDATE: I went ahead and replaced the front DS diff bearing with the ECGS bushing. Pretty easy to be honest. I still had the grinding sound, but it was greatly diminished unless I was driving over 50 miles/trip and only when I would be turning slightly left on a decline. I went ahead and bit the bullet and pulled the spindles and had the bearings replaced. She rolls super smooth now! However, the sound is still present. I'm beginning to wonder if it's the passenger side ball bearing in the axle tube that's causing the noise.
From what I've read, there is a needle bearing on the passenger side of the clamshell behind the stub axle tube. This is coming from a 1st gen Tacoma post (not sure if they're all the same components and they have the 7.5" clamshell) but they said they replaced both bearings with the ECGS bearings. Anybody know if there is any thruth to this?
Huerta
Old 01-13-2021, 07:19 PM #11
jhuerta22's Avatar
jhuerta22's Avatar
Replace front diff bearing- not the needle bearing, the passenger side? | Tacoma World
This is the link that leads me to believe there is a needle bearing on the passenger side that matches the one on the driver's side. About halfway down, Taco '09 stated this:
"The passenger side actually has the same needle bearing up against the diff as the left and it is even the same part number. The difference is the driver's side has a CV shaft directly entering the bearing, but the passenger has a short stub shaft directly entering it as part of the ADD. I have replaced the passenger side needle bearing with the ECGS bushing on two Tacos."
So can anyone verify that the clamshell has the two needle bearings?
Huerta
Old 12-06-2021, 10:57 PM #12
jhuerta22's Avatar
jhuerta22's Avatar
UPDATE: I was taking a trip a month back that was about 200 miles round-trip and the sound came back. Since then it's pretty consistent from 30 mph on up. Would it be worth tearing off the Passenger side CV, stub axle, and doing the same bearing replacement on the passenger side? I'd love some input. Also, at 343k now so there's a lot going on with the drivetrain and suspension parts that I will need to address in the near future (outer tie rods, rear axle seals, rear brakes, and an alignment). Good news is I managed to snag a spare 3.4 this summer with 115k on the odometer so I'm prepped for when the old dog gives out on me. Fingers crossed it isn't any time soon.
Huerta
Old 12-07-2021, 05:36 PM #13
Real Name: Jerod
Real Name: Jerod
I wish I could be of more help. Front axle repairs is literally the only area of these 4Runners I haven't touched, I've repairs or torn down to the frame every other spot on a 4Runner. Mine also makes a "roaring" noise that I've pinned to either these same bearings or the front wheel bearings. I just keep driving it but it sounds like you're at the point where the 4Runner is really starting to get your attention.
326WHP 347TQ
Old 06-23-2022, 11:46 AM #14
jhuerta22's Avatar
jhuerta22's Avatar
Update 06/2022
So, believe it or not, it turned out to be the REAR bearing on the passenger side. I knew the seals were starting to leak, but with the noise coming from the front I didn't even consider it. My friend who did the repair said that it fell apart after the axle shaft came out of the housing. He thought that the noise more than likely was traveling up the drive shaft making it seem like it was a front end issue. I drove it 6 hours back from KC and it NEVER made that sound again.
Huerta
Old 06-23-2022, 01:11 PM #15
Real Name: Jerod
Real Name: Jerod
That's good that you caught it!! Sounds like it was about to leave you stranded.
Unfortunately for me I've already had all bearings replaced in the rear end and still have noise. So I made my exhaust louder so I don't hear it.
326WHP 347TQ
brake , grinding , intermittent , metal , rotors
Diagnosing A Grinding Sound/Some Intermittent Starting Issues sdwaltz 3rd gen T4Rs 4 10-09-2017 11:21 PM
Is it okay to use 4WD Hi on dry pavement? adoihcj 5th gen T4Rs 75 03-02-2017 04:10 PM
4wd on Dry Pavement on Sr5? rcooper 4th Gen T4Rs 2 01-06-2013 05:45 PM
4x4, but not on dry pavement? DEKA3 5th gen T4Rs 19 07-15-2010 06:49 AM
Do you guys use H4 when on wet pavement? Gavin S. 4th Gen T4Rs 11 01-11-2005 11:47 PM
