You should be fine if you have the "stay" bolt tightened(short bolt that slides in the bracket in an arc), and the main pivot bolt is tightened as well(this needs to be loose to adjust aswell). The long adjuster bolt commonly seizes, lots of anti seize and periodic checks every 2 years are in order, as well as the PS and AC adjusters. So you should be able to pull it apart and just replace the adjuster bolt if that's what you broke and can get the busted section out of the adjuster sleeve nut, if not disregard what I said..
