Old 11-14-2020, 06:32 PM #1
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
Question for guys who have done an abs delete (earlier system)
This might be obvious to some but I haven’t been able to find a definitive answer. For those of you who have deleted the abs pump and kept the stock master cylinder, did you run the front port of the master cylinder to the front brakes and the rear port to the rear? Would it even matter?
This is a 97 if it matters
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 11-15-2020, 08:04 PM #2
Bump. Anyone know what port on the abs master cylinder goes to the front and what port goes to the rear brakes?
Old 11-16-2020, 07:39 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The front port is for the rear brakes. The back port is for the front...;)
Old 11-16-2020, 08:44 PM #4
There are some pre-load (not sure of the correct term) and volume differences between the two ports, so very important to get them right.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-16-2020, 08:57 PM #5
yea seems like brillo is right, i'm not sure where he learned that info but i have a good guess lol
anyway I tried the back port to back brakes and front port to front brakes like you would with a non abs master cylinder because that's all I had to go by and the braking was pretty crap, it worked but I pretty much had to stand on the brakes to stop quickly, however in normal driving and braking it wouldn't be very noticeable so it could be dangerous if someone were to do that and not try a few panic stops as a test. reversing the ports now allows the vehicle to stop extremely well, I did this as part of the disk brake conversion so that helps a lot in the braking too.
Old 11-16-2020, 09:22 PM #6
ABS has saved my ass enough times on my 4Runner and Saturn I can’t imagine getting rid of it.
Old 11-16-2020, 09:30 PM #7
Mine has been disabled for a long time now, I just got rid of the pump and simplified the brake line routing. I've put lots of miles on cars without abs from the factory so I'm confident in my ability to drive conservatively and compensate for the lack of abs. When the 4runner still had it the only time it ever kicked in was when it wasn't supposed to, however it didn't cause nearly as many problems as some people on here report
Old 11-16-2020, 09:43 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Lol.. gee I wonder where..;)
abs , cylinder , front , port , rear
Charcoal Canister / EVAP System Delete? Clayton74 3rd gen T4Rs 35 02-13-2024 04:43 PM
How to: Disable DRL on your 3rd gen. (earlier models) trd_4runnin 3rd gen T4Rs 66 01-11-2024 05:23 AM
GX460 Running Board Delete Question JSparky Lexus GX470/460 6 06-29-2018 09:52 PM
Question about Intake mod ISR Delete Arnezie 3rd gen T4Rs 26 08-07-2015 08:22 AM
3rd Gen Evap cansiter - 99 or earlier mussy01 Want to Buy/Trade 2 03-06-2013 10:37 PM
