Old 10-16-2021, 08:53 PM #1
levee-11's Avatar
levee-11 levee-11 is offline
Real Name: Levi
levee-11 is on a distinguished road
levee-11's Avatar
Real Name: Levi
Opinion on TPS Sensor/Engine Code
Hey all, I've recently been getting the P0120 code on and off throughout the past couple months. It seems to only come on when I let off the gas really quick and immediately get on the brakes pretty hard for example, when the light turns full red right in front of you, or someone in front of me stops out of nowhere like Washington drivers seem to do. The code says there is an unexpected value coming from TPS or a short, and I figure the sensor is just bad as the code can be reproduced every time by letting off gas quick and braking hard. I've head of other issues causing this code such as a short or bad ECU, and I've looked for shorts and all seems well. I wanted to get everyone's opinion...
Does thinking the TPS is the problem seem reasonable considering the code is affected by how quick I get off the gas and on the brake? I think the sensor is only giving the ECU a fault for a split second because my shifting and throttle are not affected when the code pops up, and after three startups, the code always clears itself. Just wanted to make sure this sounded like a definite TPS sensor issue rather than an ECU issue before I spend the 80 bucks for an OEM from Camelback Toyota.
2002 Thundercloud Limited 3.4 4x4 M/T (Manual Swapped)
1998 Desert Dune SR5 3.4 4x4 A/T (Totalled, R.I.P)
levee-11 is offline   Reply With QuoteReply With Quote
Old 10-16-2021, 09:18 PM #2
spartacus's Avatar
spartacus's Avatar
Cleaning the throttle body might take care of it also cleaning the maf but tps sensors do go bad. You can test the tps by applying vacuum to it and then checking the resistance.
Opinion on TPS Sensor/Engine Code-screenshot_2021-10-16-19-09-42-1-jpg
code , gas , quick , sensor , tps
H02 Sensor (Bank 1 Sensor 2) P0136 Code??? petepup Maintenance/Detailing 32 01-06-2023 06:49 PM
MAF sensor relearn? MAF code after 02 sensor change shahsmerdis 4th Gen T4Rs 7 08-30-2018 03:56 PM
02 sensor opinion? Rangeroad 3rd gen T4Rs 4 05-09-2012 03:43 PM
Check engine light on: Code 24 and code 31 Clone of the Mean Classic T4Rs 3 06-19-2011 12:12 PM
Check Engine Code P0420, O2 Sensor replaced? mybenje 4th Gen T4Rs 2 08-18-2009 10:07 PM
