Old 11-16-2020, 11:24 PM #1
crespoh69 crespoh69 is offline
crespoh69 is on a distinguished road
How to remove skid plate?
Hey guys, over the weekend I tried to remove the stock skid plate, my understanding is that there's 5 bolts and I removed them, only to find that it didn't even try to fall on my face. How do you remove it? I tried banging it, pulling it down, rocking it back and forth but nothing. I need to get at the AC belt to tighten it.
crespoh69 is offline   Reply With QuoteReply With Quote
Old 11-16-2020, 11:30 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 has a spectacular aura about jgue467 has a spectacular aura about jgue467 has a spectacular aura about
jgue467's Avatar
It has a 'hook' of sorts connecting the 2nd one to the first one, might have to remove the 2nd one or at least the 2nd one's front bolts to let it drop just enough to let the hook go. Pain putting it back too....
2001 Limited 4WD - 328K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
Old 11-16-2020, 11:36 PM #3
artcell1620 artcell1620 is offline
artcell1620 is on a distinguished road
I had to remove the skid plate in order to do an oil change a few weeks ago. Removal was easy for me. It was 4 bolts - one of them was a different size, must be something the previous owner did. The skid plate has hook like things toward the front of the car so you have to wiggle it a little bit. I definitely saw it sagging as I kept unbolting one by one. Putting it back was a pain since you have to use one hand to hold it up and line it up and another hand to tighten the bolts. I ended up using the stock jack that comes with the vehicle to prop it up to where I needed it while I bolted it back on.
artcell1620 is offline   Reply With QuoteReply With Quote
Old 11-16-2020, 11:37 PM #4
Aww man don't tell me that
Old 11-17-2020, 04:33 AM #5
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton will become famous soon enough pluton will become famous soon enough
pluton's Avatar
Real Name: Keith
The undercover has 2 parts, front and rear. There are nine bolts involved, but only 7 attaching the undercover to the car, and the other 2 holding the two pieces of the undercover to each other. You only have to remove 7 if you are cool with removing the entire undercover assembly instead of just the front part. That's what I do. There are 3 up front, two in the rear, and two "hidden' in the middle. If you can get underneath and position yourself to actually see all the bolt holes, it'll all come clear. It's worth jacking up the front of the vehicle or putting the car on a lift or ramps once, in order to grok where all the fasteners are. On mine they're all 12mm hex bolts.
pluton is offline   Reply With QuoteReply With Quote
Old 11-17-2020, 06:15 AM #6
brillo_76's Avatar
Real Name: Jon
brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold
brillo_76's Avatar
Real Name: Jon
They all should be 12 mm bolts. If not, someone in the past changed a bolt or 2.
To change the oil on v6 3rd gen. You can reach through the driver side wheel well under the front flap to get to the filter. That's how I do it. I only pull my front engine skid when needed and its very easy to do.
Pulling up on ramps gives you more room to work if you wish.
1997 4X4 V6 5 Speed Sr5 4 Runner (The Tank)
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
Old 11-17-2020, 11:35 AM #7
thatoneguy's Avatar
thatoneguy thatoneguy is offline
Real Name: Ryan
thatoneguy is on a distinguished road
thatoneguy's Avatar
Real Name: Ryan
Mine only came with the 4 rear bolts. Maybe someone got tired of doing up the front three at some point.
1999 Limited w/ e-locker
Former: 1987 SR5 w/ SAS
thatoneguy is offline   Reply With QuoteReply With Quote
Old 11-17-2020, 12:43 PM #8
Endlessblockades's Avatar
Endlessblockades Endlessblockades is online now
Endlessblockades has a spectacular aura about Endlessblockades has a spectacular aura about
Unless you are the original owner, many skid plate sets have a couple missing or different length bolts from 20 years of removals (draining the radiator, diff oil, etc). I would really like to get a full set of Savage skids and am hoping for a Black Friday deal of some kind. I could pick them up in SoCal to save shipping, too. I am a little concerned that they could be easily stolen overnight unless I get some fancy fasteners to slow them down until I can get a bead on them (City life).
2000 E
Endlessblockades is online now   Reply With QuoteReply With Quote
Old 11-17-2020, 01:37 PM #9
phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold
Don't get aftermarket skids, then!
The front end should have hooks that clip on to the mini crossmember in front of the radiator. Hang the front end, then lift the rear and attach one bolt loosely. From there, get the other 6/8 started and then snug 'em all down. I also would take down both the skids together when I had the stock ones.
'16 Honda Odyssey
Old 11-17-2020, 02:27 PM #10
Impact wrench optional but very nice for this.
2000 E
Old 11-17-2020, 03:15 PM #11
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is a jewel in the rough Kanoe is a jewel in the rough Kanoe is a jewel in the rough Kanoe is a jewel in the rough
Kanoe's Avatar
Exactly this. I drop my skid plate intact for each oil change as I am OCD about slop on the skid plate. Comes off as fast as undoing 6 bolts and goes on just as fast. This is really not a hard task once you get the technique.
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 11-17-2020, 05:43 PM #12
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I use the slop as rust inhibiting solutions...
Old 11-17-2020, 06:14 PM #13
Fumoto drain valve with a hose down just below the skid plate and a form-a-funnel under the filter when removing it = no mess, even with skid plates in place.
'16 Honda Odyssey
Old 11-17-2020, 07:53 PM #14
Kanoe's Avatar
Kanoe's Avatar
Yes, these look interesting, I had looked into one. But I like my magnetic drain plug, and it gives me a chance to have a look around under there and check for any leaks or problems.
-2001 Echo D.D.
Old 11-17-2020, 10:57 PM #15
Honda pc Honda pc is offline
Honda pc is on a distinguished road
Nice idea.. I too have been thinking easier ways to do Oil change... fumoto drain valve sounds like top option...
so that leaves the OIL FILTER???...
how do you get it out with the skid plates in there...
right now... I usually take skid plate off before going to quick oil change place...they only charge me $35 out the door and there are pretty good. But I can't risk them jacking up the skid plates.
Anybody ever take a Holesaw to the skid plate for easy access direct???
Honda pc is offline   Reply With QuoteReply With Quote
banging , plate , remove , rocking , skid
5th gen T4R front skid plate/filler plate, Fort Worth TX Chubbypanda Want to Buy/Trade 1 10-05-2019 08:06 PM
SoCal - Aftermarket 4th Gen 4Runner Skid Plate + Filler Plate - $250 boxtree619 For Sale: T4R Items 2 02-04-2017 10:00 PM
How to remove skid plate Nut in frame? Greydog 4th Gen T4Rs 7 10-12-2013 11:36 AM
broke off a bolt trying to remove front skid plate 05 2wd uwrasta Maintenance/Detailing 9 12-15-2011 05:15 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
