10-11-2021, 11:15 PM
#166
I disagree!
My 2000 Land Cruiser got 65W low beams with brand new OEM headlights and it is brighter than any other vehicle I own including 21 Taco LED. LC light illuminates so good I see the road very clearly and no one in front of me flashes. it is probably the design goes into LCs.
I bought OEM (99+) toyota lights for the 97 4Runner. It is bright but compared to the TYC set I bought at the beginning of this year is quite close.
About wires. I am yet to find corroded wires in a toyota wire harness (unless exposed to weather). All other wires specially the Chinese or even Hyundai, I find the wires are getting rusted even it is covered with the insulator.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
11-09-2021, 09:36 PM
#167
I used Auxito LED drop ins on my 5th gen. Replaced fogs, and ,low beam only. The Auxito bulb chip mimicks the factory halogen filiment placement. Work perfectly in my opinion. No glare. 40 bucks a pair.
11-27-2021, 11:49 PM
#168
Glare caps in a '99 and newer
I just upgraded my daughter's '97 to a '99+ headlamp assembly. I bought the used headlamps from a U Pull n Pay and noticed that the glare caps are missing so I transferred the old glare caps from the '97 to the '99. Having never done this before, I was wondering why did someone remove the glare caps from '99 at the junk yard w/o taking the actual headlamp assemblies? Second question is can the glare caps be swapped or did the design of the glare caps change in the '99 and newer 3rd gens? I'm assuming running w/o glare caps would simply blind oncoming traffic
I took my daughter's '97 down the street at dark and noticed how shitty her lights are and I'm thinking the glare caps aren't correct for the model year or maybe I installed them 180deg off.
Anyway, I need to resolve this as winter is here and she is driving on rural roads and the last thing she needs to hit is a deer or a dog after she leaves work.
Thanks for our inputs.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
11-28-2021, 08:27 AM
#169
Technically, it only partially mimicks the factory halogen filament position. It does not provide the 360 degree "orb of light" that the halogen filament does. The light emitting diode chips are "side firing" and miss half the reflector bowl (top and bottom) in a halogen housing. Don't fall for the marketing BS.
11-28-2021, 09:40 AM
#170
Pretty sure the design changed and you need the ones from a 99+, I’m sure you could get a set cheap from someone who has done a projector retrofit. Just be aware you need the oem ones as the ones from tyc headlights that are popular to use in retrofits are defective
11-28-2021, 08:43 PM
#171
Thank you, that's very helpful.
11-29-2021, 12:33 AM
#172
Real Name: Keith
Real Name: Keith
I bought the used headlamps from a U Pull n Pay....
My observations:
New, clean 99+ headlights aren't much---if any---brighter than new, clean 96-98 headlights. I have both. First I installed new 96-98 headlights, then installed new 99+ headlights in the same '97 4Runner.
The problem is that original used headlamp assemblies are dim because the reflector and front glass have been coated with dust and airborne deposits for ≈20 years, and cannot practically be cleaned.
Best fix is NEW assemblies---OEM or aftermarket--- that are clean.
Some claim to have fixed theirs by prying the lens off, and installing new reflectors and reusing the rest of the assembly, but it's a lot more labor that way
I just bought new complete assemblies and the headlights are..well...like new.
12-09-2021, 01:29 AM
#173
Originally Posted by pluton
My observations:
Did you buy OEM assemblies?
Sent from my SM-G960U1 using Tapatalk
12-09-2021, 01:37 PM
#174
Well said: I felt the same way after installing OEM brand New 99+ (multi point reflector) headlights into my 97 4runner which originally came non-clear front glass. I have a collection of headlights now!
"New, clean 99+ headlights aren't much---if any---brighter than new, clean 96-98 headlights. I have both. First I installed new 96-98 headlights, then installed new 99+ headlights in the same '97 4Runner.
I just bought new complete assemblies and the headlights are..well...like new"
12-10-2021, 02:10 AM
#175
Real Name: Keith
Real Name: Keith
Sequence of events:
2013: Bought '97 4Runner.
2019: Lived with dim old lights until backing frame broke on one side.
2019:Bought/installed new OEM 96-98 headlights. Everyone says the 99+ units are better, but Toyota USA ran out a few years ago.
2019: New 96-98 units are brighter.
2020: Realize that Amayama sells the OEM 99+ units at reasonable price.
2020: Bought a pair and installed the 99+ units.
2020: The fresh, clean 99+ units are not substantially brighter...maybe not any brighter... than the fresh, clean 96-98 units.
So...now I have 99+ headlights installed, and a good, clean pair of 96-98 units as spares.
If I knew then what I know now, I wouldn't have bothered to get the 99+ units. The new, clean 96-98 units were fine.
12-10-2021, 07:54 AM
#176
To be fair, the main reason 99+ are recommended so heavily is that they have a glass front vs a plastic front. If you've dealt with plastic headlights, they suffer from road debris damage (being sanded with dust), hazing and yellowing. It can be fixed, sort of, but those fixes never last very long... a couple years at best. Glass doesn't have any of that issue.
12-10-2021, 08:02 AM
#177
The 96-98 are also glass.
12-11-2021, 03:03 AM
#178
Real Name: Keith
Real Name: Keith
This is correct. There may be aftermarket 'identical fit' units that use plastic.
12-11-2021, 09:24 AM
#179
The more you know.... I was under the impression that even the OEM's were plastic till 99. Guess that means I have an easy decision then as I was avoiding buying OEM 96~98 to replace my 99's that are falling apart inside, heard nothing good about the TYC and can't stomach the looks of the projector retrofits.
I like it when I'm wrong about something but that works out in my favor anyway.
12-11-2021, 11:32 AM
#180
I have a new set of glass 99’s for install, and can confirm that they are indeed glass.
I’ve been running sylvania silverstar ultras. Good light throw and the OE housing doesn’t create and dead zones or spots.
It’d sure be nice to have a complete OE level LED direct DOT rated replacement housing. A good one. Not some jankey chineseium pos….
Some projector retrofits looks amazing, and others look like total garbage. I know that HID isn’t for me. I have had family members and friends that have ran them and pick ups and they do seem to be quite a headache. Certainly not an install it and forget about it solution.
It would be nice to have a simple installation better lighting solution with form like a halogen. The halogens are kind of no drama, you just plug them in twist them in and saw the cap and that’s it. It’s easier said then done I guess.
I do know that all these new cars on the road have holy hell of bright glare though….. apparently that’s how you combat it, have equally brighter LEDs….
To anyone that reads this, good luck on finding an LED halogen replacement bulb that doesn’t suck. I’ll bet I’ve tried 7 or 8 different ones except the 200$+ headlight revolution options on my Ram. What a clownish joke and a waste of time. Light beam looked like a disco ball…..All sucked so horribly. And they created silly amounts of oncoming glare.
I probably have 200 hours tooling around with BS replacement leds. Haven’t found one that isn’t craptastic yet.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
