Old 11-26-2020, 12:21 AM #91
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Originally Posted by pluton View Post
If they're NOS and faded, yellowed, corroded, filled with dust...refund time.
If they're OE approved new/aftermarket, then fine...I'll get better lights than I had. If they're TYC with a different badge on them, then, yes...I will have overpaid, and proven the 'stupid' part of my 'rich and stupid' formulation from the earlier post.
Mine don't look like old stock. Definitely a step up in quality from the TYCs. I don't think the TYCs had the rubber vent hose on the back and the rubber bulb housing on the back was kind of chintzy.
Sent from my moto x4 using Tapatalk
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 11-26-2020, 04:07 AM #92
Originally Posted by 96RedRunner View Post
Since harness on the way been scoping the job I lied saying 3' wire would do it, ha.
Print shows body ground at R/S bucket, goes to Batt plus L/S bucket.
Plan is to run a 10ga wire from R/S bucket to L/S bucket to Batt, isolated ground clean power.
My plan was to remove the terminals on the ground wires and splice those to one long 14 gauge wire running back to the negative battery terminal. Nothing in that harness is bigger than 14 gauge so I figured that would be sufficient.
Old 11-26-2020, 10:40 AM #93
nissanh nissanh is offline
I bought a TYC to the passenger side (after reading your thread and other's views). I am already running 100/80W bulbs with stock wiring. I am very happy to report the passenger side light throws a LOT of light on the road now, a massive improvement!
The TYC light has 2 rubber vents in the back, those are not as long as OEM toyota but those are there. I saw it.
Old 11-26-2020, 01:20 PM #94
Cool. I didn't specifically look. I just didn't remember seeing them. Glad it worked out for you!
Old 11-27-2020, 12:07 AM #95
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Originally Posted by texadelphia View Post
My plan was to remove the terminals on the ground wires and splice those to one long 14 gauge wire running back to the negative battery terminal. Nothing in that harness is bigger than 14 gauge so I figured that would be sufficient....
Think about what your doing by doing this, your doubling the load on the single 14 ga wire. Ground sized for both loads in this case, you benefit by running this to R/S, circuit efficency Ohms Law what we after.
With your soldering iron and solder. Pic is blurry what size solder did you choose ? .035"-.045" dia. works best with that tip, chisel tip better for larger solder. Was tip tight in heat element where it screws in. New out of box could be a dud, check temp, who doesn't have an I/R thermometer now days with the WOO Flu, lol.
Old 11-27-2020, 12:35 AM #96
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I purchased a set of used lights from a member here. He shipped them to me in one of the OEM boxes he got. Order date was last year, so definitely not NOS. When I called my wholesale buddy @ Toyota of Richardson a year or 2 ago, he said they were still being produced and stocked regularly at the warehouse.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 12:47 AM #97
Yeah, I was wondering about that. Guess I'll run each ground back to the battery individually.
Solder is 0.062 diameter. Tip is screwdriver tip. I think it's a dud with a loose connection. Iron went completely cold a few time despite being turned on. Ordered a nicer Weller model as a replacement.
Old 11-27-2020, 01:59 AM #98
Real Name: Mark
Real Name: Mark
Yeah, I was wondering about that. Guess I'll run each ground back to the battery individually...
Your choice I'd still go bigger 12-10 ga still a benefit.
This like wiring a Amp best power I can get, think it'll payoff powering the bulbs.
Going OCD or close on this Mod, No winter time blues.
Ground side all I can layout at the moment. A $25.00 plug n play harness could be coming, $25.00 of parts snip here snip there we'll see.
$25.00 down the drain.
Old 11-27-2020, 11:33 AM #99
I got my Amazon harness and the only thing I’m going to do to it is extend the grounds back to the battery. I’m going to mount the relays where the fog relay it mounted at the battery tray.
Old 11-27-2020, 01:06 PM #100
I guess I figured the power going to ground was essentially limited by the power going in through the single 14 gauge wire going to the positive terminal. Can't get out more than goes in right?
Old 11-27-2020, 01:16 PM #101
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
My passenger side TYC headlight's beam pattern is fine too, it's the driver side ones that have beam pattern issues.
Old 11-27-2020, 03:54 PM #102
Real Name: Mark
Real Name: Mark
I guess I figured the power going to ground was essentially limited by the power going in through the single 14 gauge wire going to the positive terminal. Can't get out more than goes in right?..
A given voltge over a given distance with a given wire size has a percent of voltage drop which effects amp draw.
There is a varible percentage range of acceptable voltage drop for a given load type and voltage DC AC
I'm aiming for .5%+- voltage drop since it is the headlights, ground is half the circuit harness is other.
Any electrical advantage is a good thing, https://cdn11.bigcommerce.com/s-hw84...208230.jpg?c=2 Comes in handy
Will harness achieve that out of box we'll see.
Old 11-27-2020, 04:55 PM #103
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Ahh, all these 4Runners with brighter headlights make me happy. Drive safely and confidently!
326WHP 347TQ
Old 11-27-2020, 05:11 PM #104
Real Name: Mark
Real Name: Mark
Aim these brighter lights correctly in there somewhere.
Old 11-27-2020, 05:47 PM #105
raKnizek's Avatar
raKnizek raKnizek is offline
Real Name: Alex
raKnizek will become famous soon enough
raKnizek's Avatar
Real Name: Alex
Anybody have or planning to use this harness upgrade with factory fog lights? Will that matter or impact anything? I noticed one of the harnesses mention that it is not for DRL or factory fog equipped 3rd gens.
2000 SR5 3.4, Manual, 4x4
Icon 2.5 extended coilovers & 2.0 rear, JBA UCAs
265/75R16 General Grabber X3 on LC80s
Full Skid Plates
raKnizek is offline   Reply With QuoteReply With Quote
audi , drop-in , elk , lights , upgrade
FS: Infinity Primus 5th Gen Drop In Audio Upgrade (San Francisco, CA) $200 Xtremluck For Sale: T4R Items 2 01-09-2019 05:38 PM
Auto Headlight setting and Drop In HID Kit... SendInTheCavalry 5th gen T4Rs 7 12-08-2018 01:31 AM
Headlight upgrade? Gryphon Classic T4Rs 14 10-10-2016 11:35 AM
Headlight upgrade WXman 4th Gen T4Rs 24 11-25-2013 10:28 AM
3rd gen. Headlight upgrade cld417 Classifieds - buy & sell (no commercial ads please) 0 02-24-2010 08:22 PM
