Old 01-16-2022, 12:59 PM #1
Bucket81's Avatar
Bucket81 Bucket81 is offline
Real Name: chris
Bucket81 is on a distinguished road
Bucket81's Avatar
Real Name: chris
Is Discount trying to get me to buy wheels?
I just installed a lift and headed over to Discount for a new set of tires. I wanted to go bigger currently I am running the factory wheels with 265/75 16x7 I think they have a 15mm offset. I was planning on putting a set of Sequoia 17x7.5 with a 15MM offset which would tuck a bit more. The guys at discount are saying I can only go as big as 275/70 those wheels because of the offset. They are worried it will hit the upper control arm. Are they just trying to sell me wheels?
On another note, I found a set of BBS FJ wheels but I haven't been able to find specs on them the ad says they are 17x8 with a +5mm offset. I'd really like a reason to buy these...
Bucket81 is offline   Reply With QuoteReply With Quote
Old 01-16-2022, 02:04 PM #2
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
The wheel isn’t really as much the issue, but more so that the next size up (285/70/17) being a risk of interfering with the UCA unless you run aftermarket UCA’s, wheel spacers or higher offset wheels. Some people get that combo to fit without rubbing, some people don’t. It’s a gamble, so they’re telling you what they know will fit without issues.
The 275/70/17 is roughly inbetween a 265/75/16 and a 285/75/16, so you’re getting a pretty good sized tire in there without pushing the wheels out further. If the 285/70/17 is the size you’re set on, I’d either plan on SPC upper control arms, spacers or a different wheel to avoid fitment issues.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 01-16-2022, 04:36 PM #3
Bucket81's Avatar
Real Name: chris
Bucket81's Avatar
Real Name: chris
I actually just ordered some JBA UCA! I had it in for an alignment and it looks like one is bent so I figured I'd order some and see if they give me more clearance. I wish those FJ wheels weren't 8in wide...
Old 01-16-2022, 04:44 PM #4
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Off the top of your head, what offset wheel do you believe would work without SPC UCAs for 275/75/17? I may have an opportunity to pick up a set of wheels/tires that were on a Sequoia(?) VERY cheap! I can get the geometry specs-BS, OS, but don't have them yet. I am currently on 265/75/16, 1.25" spidertrax and about 2" lift W/stock UCA. TY
Old 01-16-2022, 06:54 PM #5
Real Name: Evan
Real Name: Evan
There’s so many threads out there that should have some wheel backspace specs if you’re willing to go down the rabbit hole, although that tire size is a bit less common it seems. I would think a 4” backspace is enough to keep the tire off the UCA. Shouldn’t need crazy 3.5” backspacing to clear a little extra sidewall width.
Old 01-16-2022, 07:10 PM #6
Twan's Avatar
Twan Twan is offline
Twan will become famous soon enough Twan will become famous soon enough
Twan's Avatar
I had to run 2" spacers to clear the UCAs with 285/70/17 KO2s on Tundra/Sequoia split 5 spokes. I ended up switching to a set of 17x8.5 wheels with -12 offset 4.27 BS and got rid of the spacers.
2000 SR5 Sport - 4EAT and E-locker, King 2.5s, EimKeith PCK, SPC UCAs, 33" KO2s on Black Rhino Boxer gloss gold 17x8.5, Savage/Lotus skids, 4xInnovations front bumper/sliders, Shrockworks bumper & tire carrier, Lil Skip Gas Tank Skid, Magnaflow Overland cat back
Twan is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 01:11 AM #7
Real Name: Blair
Real Name: Blair
Thanks guys. I should have looked into the sizing question and was being lazy. I decided not to bother since the wheels are not a style I could live with after I saw a pic.
Old 01-17-2022, 08:48 AM #8
Bucket81's Avatar
Real Name: chris
Bucket81's Avatar
Real Name: chris
I didn't really want to go down the custom wheel rabbit hole. I'd like to get the FJ wheels I found but the offset just isn't right.
15mm , discount , offset , set , wheels
Discount Tire blaming Toyota for vibration on their wheels? Samm25 4th Gen T4Rs 18 11-20-2018 06:04 PM
the discount tire direct eBay discount is on again! silver4est 3rd gen T4Rs 36 03-13-2017 03:39 PM
Hey guys discount has some great wheels on sale rok medic 5th gen T4Rs 28 12-05-2015 03:15 PM
Discount Tire Direct discount.... Casper 4th Gen T4Rs 0 10-17-2007 10:57 PM
