Old 11-17-2020, 10:48 AM #1
llopness llopness is offline
llopness is on a distinguished road
Electric brake booster upgrade.
What's required to put an electric brake booster from an 01-02 3rd gen into an earlier third gen?
I've tried searching so if you know of threads discussing this please link them instead of telling me to search.
llopness is offline   Reply With QuoteReply With Quote
Old 11-17-2020, 12:42 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Why do you want to? Do you currently have ABS?
Old 11-17-2020, 04:09 PM #3
Swapping a Diesel engine. Removing the need for a vacuum pump would be nice.
Old 11-17-2020, 05:37 PM #4
Real Name: Patrick
Real Name: Patrick
You still need a vacuum source for the brake booster. The 2001-2002 brake units integrated the abs pump/module with the master vs having them separate for earlier years. What diesel are you going to swap in?
EDIT: To clarify, all 3rd gen 4Runner's use vacuum for the brake booster.
Old 11-17-2020, 05:53 PM #5
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
you'll probably want to just use a vacuum pump and not mess with changing the booster, the newer booster is very expensive and still vacuum actuated, I think the 4th gen booster might be electric but it's also very expensive and who knows how hard of a swap that would be, probably not worth it.
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 11-17-2020, 06:12 PM #6
Swapping the body, frame, all electronics...
Well, kinda. The brake booster is also the ABS and traction control system in the 01/02's. ABS was changed from 3-channel to 4-channel, so almost all of the brake lines are different, it uses a completely different ABS computer, integrated differently into the dash harness. Heck, it is even (partially) integrated into the engine control system with the sort-of drive-by-wire system for the throttle.
Use a vacuum pump. The diesel motor should already have one - either electric or mechanical.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-18-2020, 07:05 AM #7
sounds like it's above my expertise. Considering how the Prius Electric steering is a simple upgrade for older cars, that the electric brake boosters, like the UZJ100 and such would gain some traction as a swap or upgrade.
Old 11-18-2020, 01:42 PM #8
The issue is that it isn't just an electronic booster, it is a booster, ABS system and traction control system in one unit - which requires a specific set of sensors and computers to run it.
Old 11-19-2020, 02:21 AM #9
pavelvoivoda's Avatar
pavelvoivoda pavelvoivoda is offline
pavelvoivoda will become famous soon enough
Al the systems that are incorporated into the latest 3rd gens, are TRAC, VSC, ABS, EBD, and BA. Only one ECU does all that.
I was thinking of making this type of a conversion on my diesel Runner, as it would have been really a great achievement to have all those systems on manual transmission and mech diesel engine, but it was not possible with my current setup.
As Charlie mentioned, the hydraulic brake booster from the latest 3gens, is far to complex to be just bolted in. Even tho it's the best of all the vehicle stability control systems, it is integrated into automatics only.
So if yo plan to install it into a manual 4Runner, it is not possible as the logic is designed to work only with automatics.
Component wise, the system consists of the brake booster, a controller under the steering wheel, a few sensors more than the abs system, like the yaw rate sensor, a steering sensor, and an additional box with 3 relays. You will have to exchange all the piping to make it work too.
And as mentioned earlier, the VSC is integrated into pretty much all the other systems - engine control, 4WD control, Cruise Control if you have it, and the combination meter, with all the lights for it.
If you install an electronic diesel engine with the same automatic as the 5VZ, you could make the system work. But if your diesel engine is with a mech pump, then you have to spoof the VSC ECU that it has a connection to and control of the engine, more specifically the engine's throttle body sensor, and RPM sensor.
You could technically create a homemade simple ECU from arduino or raspberry pi to simulate that there the VSC ECU has control over the engine itself, but that further complicates the retrofit, as your choice of the diesel engine is one that at least has control of the transmission - therefor an electronically controlled engine.
"Sadly, unlike the Bill of Rights, the UDHR has no 2nd amendment, rendering it useless. Remember that."
2person xUN diesel T4R equipped for long distance touring w/ light-duty off-roading.
1000kms range w/ subtank
pavelvoivoda is offline   Reply With QuoteReply With Quote
booster , brake , electric , gen , threads
Electric motor sound from under dash - NOT BRAKE BOOSTER. Montego Murph 4th Gen T4Rs 7 11-28-2020 11:27 AM
anyone have electric brake booster problems/failure? NJshadow93 4th Gen T4Rs 10 10-19-2020 09:05 PM
3rd gen electric brake booster-any out there? rebel4x468 3rd gen T4Rs 3 10-29-2017 03:05 PM
Electric Brake Booster or Master Cylinder going bad? judogti 4th Gen T4Rs 8 04-28-2017 05:07 AM
Electric brake booster jmauld 4th Gen T4Rs 8 06-30-2015 09:17 PM
