11-16-2020, 11:25 PM
Throttle body gasket
I will be pulling the entire throttle body on my 1996 V-6 T4R, to clean the throttle with CRC throttle body cleaner. Question: In addition to the NEW throttle body gasket, do I need to also use a gasket sealant ? Or is the NEW gasket enough ?
11-17-2020, 12:15 AM
Real Name: Devan
Real Name: Devan
No sealant on the throttle body, or anywhere on the intake, as far as I know. I've done my knock sensors (multiple times) which requires removing the entire intake and didn't use a drop of sealant anywhere, only gaskets. No vacuum leaks anywhere.
11-17-2020, 12:41 AM
Can confirm, no sealant on the intake (including the throttle body)
11-17-2020, 01:06 AM
Real Name: Jerod
Real Name: Jerod
Don't worry, this isn't a GM vehicle. Toyota actually designed its gaskets to seal the connections.
11-17-2020, 02:06 AM
Thanks, guys. I appreciate it.
11-17-2020, 10:59 AM
No sealant.
But, if you're switching the gasket out for a new one, this one is really nice:
Teflon Heat Isolation Gasket - 5VZ Throttle Body
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
11-17-2020, 06:45 PM
Just a reminder...don't crank on the bolts reattaching the throttle body. Torque spec is a lite 13 ft lb.
Most tend to crank on the bolts thinking to seal out vacuum leaks.
11-18-2020, 12:44 PM
Are you cleaning the IAC valve as well? You will certainly need a new gasket for it.
If you are not removing the IAC be careful not to let any gunk run down into it.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
11-18-2020, 03:19 PM
Real Name: Devan
Real Name: Devan
I crank on them and never experienced a problem once. Dont put my body weight into it but certainly dont worry about going over 13lbs. Torque spec is nothing more than a minimum, what's the worst that could happen?
11-18-2020, 04:22 PM
Real Name: Patrick
Real Name: Patrick
Bolt snaps or bolt threads strip out
11-18-2020, 05:58 PM
I use a 1/4 drive and two fingers. Never needed a torque wrench for smalls unless it is a head gasket on my dirt bike. 13ftlbs.
11-19-2020, 12:51 AM
Yes, I will be removing and cleaning the IAC. Are you saying that I'll need a separate gasket for the IAC (in addition to the throttle body gasket) ????
11-19-2020, 09:45 AM
Real Name: Patrick
Real Name: Patrick
IAC has a separate gasket to seal it to the throttle body
11-19-2020, 11:04 AM
It's a figure 8 shaped o-ring in there. It's kind of important since one passage is for coolant flowing through the IAC and throttle body.
Make sure you use a JIS screwdriver or a VERY GOOD phillips on the IAC screws also. Lots of people have had problems stripping the heads. My Klein phillips fits them very well and had no problems.
-2001 Echo D.D.
