Old 11-18-2020, 11:03 PM #1
Wraytex Wraytex is offline
Wraytex is on a distinguished road
Rear bearing and seal kit question
Just making sure this will work for my 2000 limited 4x4 with rear locker..
OEM KOYO Rear Wheel Bearing W/ ABS Skid Control Ring Gear For Tacoma / 4Runner | eBay
When i look those koyo bearings up on amazon, the filter says it won't fit mine with ABS. Granted that's just the bearings but I'm not seeing them with a compatible bearing outside of the oem. Thanks in advance, Tim.
Wraytex is offline   Reply With QuoteReply With Quote
Old 11-19-2020, 12:01 AM #2
marcus clarkus's Avatar
marcus clarkus marcus clarkus is offline
marcus clarkus is on a distinguished road
You could always try asking the seller. You should also check to make sure it’s the updated inner seal (Toyota 90310-50006).
I just used the Marlin Crawler kit and bought the updated inner seals from Amazon. Everything is working great.
1999 Toyota 4Runner SR5 V6 4x4 5spd - 317k miles as of Feb 2024
3D Printed SR5 Mudflaps
FS: 3D Printed Outlet Covers - Convert rear ashtray to 12V/USB outlets
marcus clarkus is offline   Reply With QuoteReply With Quote
Old 11-19-2020, 09:48 AM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
That looks like the bearings I used when I replaced mine. If you are using a press you can reuse the abs tone ring. You only need 2 new retainers as well for where the inner axle seal rides. You can reuse the retainers by the bearing.
Old 11-19-2020, 08:11 PM #4
Thanks for the replies, I had already sourced Toyota seals but wouldn't mind having an extra set. One of my tone rings is buggered from previous owners time. Probably still works but I'll replace it. I've watched Timmy's video and will be patronizing the eBay guy he recommended for the axle tool.
bearing , bearings , fit , mine , rear
Front wheel bearing seal question Monkey Wrench 4th Gen T4Rs 10 06-20-2022 12:12 AM
Leaky Rear Axle Seal/Oil in Bearing? Seattle206 5th gen T4Rs 20 12-21-2017 09:09 PM
Ready to do rear axle seal/bearing job. RS Dude 3rd gen T4Rs 4 04-19-2016 02:25 PM
Replace Rear bearing, outer seal & retainers or just inner seal? Pauly67 3rd gen T4Rs 10 10-18-2012 10:05 AM
Rear bearing and seal bbodily New Members 0 04-12-2011 08:09 PM
