Originally Posted by spartacus
Did you record the sound while'driving from the cab?Where is the noise coming from the engine bay front or back of the motor underneath. Some info would be helpful. Take the belts off one at a time. check the flex plate inspection cover off check the flex plate for cracks. Go from there.
The sounds seems to be coming from the back of the instrument panel. First it started off as a gingling, like keys, but coming from inside the steering column. Then that sound started once I got my truck up to highway speed. I pulled over and had it towed to the dealership.
Unfortunately I’m not a DIYer like you guys. But if you have any idea it sure would be helpful. Please ask me anything else.
'98 4Runner Ltd 4WD.
A Ford might get you from point A to point B. But a Toyota will always get you home.
