Old 11-24-2020, 04:09 PM #16
Speedy's Avatar
Speedy Speedy is offline
Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough
Speedy's Avatar
Oh gotcha, I only tightened the ones I could reach. Another reason I used the proper torque wrench. My valve covers weren't (aren't) leaking anywhere but on the passenger side rear corner and that is the bolt that was very loose for whatever reason. I wish I could easily reach them all but better than nothing I reckon. The fact I didn't have any other leaks pointed me to checking the bolts to begin with actually.
Speedy is offline   Reply With QuoteReply With Quote
Old 11-25-2020, 11:59 AM #17
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Back when I was a rookie a couple of years ago DIY'ing my car to avoid taking it to the shop, I did the valve cover gasket job and thought to myself that the bolts needed to be very tight to "seat correctly." I heard both valve cover snap and knew I was in deep trouble. I had to go to a junkyard to get 2 used covers off another 4Runner and it has been good since. I got very lucky as both covers were only $6 (new were $300+).
Lesson: Use a torque wrench and don't crank on the bolt. It's not supposed to be very tight. In your case since it's leaking - change the rubber gasket. Yeah it's a lot of work, but you already know the meaning of "Do it once, do it right."
Get a new plentum gasket while you're at it. I didn't replace mine but oh well, it's still running fine.
______________
2000 Toyota 4Runner 4x4 Limited Sport Edition V6
Old 11-25-2020, 03:30 PM #18
Speedy's Avatar
Speedy's Avatar
Not sure tearing in to it is the best advice at this point. Been over a week and I've checked the valve covers twice with a white rag. Clean as a whistle.
Looks like just torquing the bolts to spec was my fix and took 5 minutes. If it ever leaks again I'll update this thread, but so far so good.
Eventually I'll need to do the timing belt, water pump, I'll do the VC gaskets then and prob replace the radiator as well, but hoping I can make it to 200k miles for all that.
cover , loose , oil , smell , valve
So, did I get lucky? funshot 5th gen T4Rs 2 09-28-2017 10:40 PM
I got lucky with this one... runner707 General Discussions 14 01-18-2013 01:55 AM
Lucky 7s AKUMA03 4th Gen T4Rs 1 05-29-2011 01:53 PM
one VERY LUCKY S.O.B. 00void 4th Gen T4Rs 8 03-08-2008 02:08 PM
Bad news for me...but I'm still Lucky linhsy 4th Gen T4Rs 106 08-13-2004 08:40 PM
