Old 11-23-2020, 10:25 PM #1
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Original Spare Tire From 1997 - Use or Avoid?
My 4Runner got a screw in the tire and is losing air. I can keep it pumped up for about 2 hours before it goes flat. I got it home and proceeded to put on the spare which I've never used before. I look up the manufacturing code and low and behold, it has a tire date stamp of November of 1997! The tire is brand new and never been used so I assumed it had been replaced at some point! My 4Runner has a production date of September of 1997 so that's consistent with when it would have hit US shores after being made in Japan.
My question is, should I use it? I keep it full with air and it holds pressure with no issue but it's 23 year old rubber and has never held the weight of the vehicle (still has all the production marks and little rubber pieces on the tread). No visible cracks or imperfections. I carry an air pump so I can fill my tires any time I need so I can still run the leaking tire instead. My commute to work is 2 miles and the place I bought the tires is about 5 miles away so nothing crazy.
Learned today that my 4Runner came with Goodyear Wranglers when new.
326WHP 347TQ
Old 11-23-2020, 10:50 PM #2
nissanh nissanh is offline
Please avoid using it. It can rupture at any time.
I thought pre 2000 don't have the DOT code. Mine is also Goodyear Wranglers and old as yours. It has cracks but still holds air.
PS: I saw you recommend TYC headlight on another thread. I bought one and that is glass and is in excellent condition. I have Hella 100/80W light with OEM wiring. Yet to check the brightness. thanks for your input about TYC. It is a good brand unlike cheap Chinese parts.
Old 11-23-2020, 10:50 PM #3
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Is this satire? Absolutely do not.
There is NEVER a reason to run MayPops if you don't have to. The right way to look at this question is "should I be an unpredictable danger to others?"
To that effect, it seems a little ass backwards to gamble on what should be a last resort/recovery method, that's like finding a winch in the dumpster and immediately heading to the mud pits. All I see is losing a tire, putting on the spare and losing that within a mile or two.
I could happily direct anybody to my old supervisor that lost an eye from trying to fill a ~30 year old tire; blew right in his face. Dry rot can be VERY sneaky.
Old 11-23-2020, 10:59 PM #4
Real Name: Jerod
Real Name: Jerod
Thanks, I've just never encountered a tire this old before! Odd since this is my 5th 4Runner... every other one has had the spare replaced at some point.
It did have the DOT code on it, it's the 3 digit date format of WWY, first two digits are the week of manufacture and the last is the year it was made. The 3 digit code shows that it was made in the 90's, has a code of 477.
326WHP 347TQ
Old 11-23-2020, 11:53 PM #5
Outrider Outrider is offline
Outrider will become famous soon enough
I'm glad to have seen this thread, as it made me realize that I have owned mine for almost 12 years, never had a flat in that time, and only pulled the spare down only to check pressure periodically through all of those years. It has held air fine all of that time, only needing a minor top-off every year or two. But, it may very well blow to kingdom come if I ever have to use it.
I will shop for a used replacement tire, which is only a few years old, for it.
I try to make a habit of checking the pressure in the spares of all of my families vehicles when I check the driving tire pressures. It would really suck to get a flat, pull out the spare, and find it flat, too. I have found that the donut spares on many cars don't hold pressure nearly as well as regular tires, for some reason.
Also, we bought a used Camry for my wife many years ago. It got a flat. I pulled out the spare and found that it had a different freaking bolt pattern than the hub. Apparently, the previous owner (a car flipper) just went to a junkyard and told them to sell him any spare tire. I then went to a junkyard and got a spare that actually fit it. Then sold the old spare by stating that I had no idea what it fit, but I specified the bolt circle.
'99 SR5 V6 2WD named Jolene / In the T4R 200 Club
Outrider is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 12:22 AM #6
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
If you want to have fun and satisfy your curiosity, mount the ancient spare and drive the 5 miles to the tire place at about 5-10 MPH. Do not take it up to any speed where catastrophic failure could be dangerous for you or others around you.
pluton is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 05:06 AM #7
I’ve used the old spare on the limited puppy hauler no problems.
Old 11-24-2020, 08:47 AM #8
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Load it up with 65 psi or so see if it pops or leaks, drive it like you stole it.
Old 11-24-2020, 09:42 AM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I would drive it as needed, but replace it when you get your tire fixed. #1 enemy of tire rubber is UV exposure which wasn't an issue if stored in the factory location. If there aren't any cracks or bulges then it's good to drive in my opinion.
Old 11-24-2020, 11:49 AM #10
rickmum's Avatar
rickmum rickmum is offline
rickmum is on a distinguished road
rickmum's Avatar
I would think it's not worth the risk, man.. 23 year old rubber? Hell naw.
1998 Desert Dune Limited w/ rear diff locker
300,000 kms
rickmum is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 12:38 PM #11
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
This. It's probably fine but use at your own risk. I've done it.
air , miles , rubber , spare , tire
Spare Tire location tire size limits Ogre75 5th gen T4Rs 3 03-06-2020 01:11 PM
FS: 5th Gen-Set of 4 Stock Tires (3k Miles) + Original Spare(Unused) $500-Denver,CO Spudgey For Sale: Suspension/Wheels/Tires 3 08-14-2017 09:09 PM
FS: 2016 4runner Trail - 4 Wheel/Tire Combo + 1 spare tire (Houston, TX) brg128 For Sale: Suspension/Wheels/Tires 2 03-21-2016 08:54 AM
Largest fully inflated 16" spare tire that will fit in the stock spare location? 240m3srt 3rd gen T4Rs 16 09-26-2013 01:30 PM
