Originally Posted by 8355adam
I have spent a ton of time replacing my timing belt, water pump and all the usual seals etc. I go to fill up my radiator and coolant starts leaking (gushing) from the bottom of the engine. I am double sure I torqued all the water pump bolts to the correct 14ft/lbs and I used a new gasket that came with the pump. I followed a DIY on this site... I used permatex ultra black with the new gasket is this not right? Some people say use gray but honestly I didn’t think there would be much of a difference.... what did I do wrong? Has this happened to anyone before?
This is most likely your problem. You do not use any kind of sealer on the water pump gasket.
The only thing that doesn't make sense is that you said coolant is "gushing" out. I would think it could leak because of the gasket/sealer combo but not "gush".
Before you tear it all apart, make sure there isn't something obvious that explain the gushing coolant.
Unfortunately it sounds like you're going to need to pull it back apart to fix it. I would order a new OEM gasket and make sure you clean up the WP and sealing area really well.
I'm not sure which video/write up you used but I suggest using Tim/Seans videos that can be found on Youtube.
Here it is.
Good luck
